Has anyone ever built or seen an engine brace?
Old Jan 20, 2003 | 10:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I was wondering if anyone has any pictures of an egine brace. Not a torque plate, but just something like a simple brace which goes between the engine and frame.
Old Jan 20, 2003 | 11:37 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well I seen it on some import cars but never on a V8.
Old Jan 21, 2003 | 12:46 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
I used to know a guy that had a built up 454 in a mid 60's chevelle, he kept breaking engine mounts with it so he ended up wrapping a logging chain around the engine (no idea how he attached it) and welded the chain the the frame...iit eventually broke the chain apparatus and he sold it...i dunno how good a job he did on mounts or the chain, but i remember him always half assing projects...
Old Jan 21, 2003 | 09:10 PM
laiky's Avatar
some gararge door cable and clamps makes a good torque strap
Old Jan 22, 2003 | 11:41 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Heres one CE makes for the 79-93 Mustang, i've been thinking of buying one and adapting it... PN 247-4010 from Jegs.
Attached Thumbnails Has anyone ever built or seen an engine brace?-enginelink.jpeg
Old Jan 22, 2003 | 12:54 PM
Morley's Avatar
I've seen people just use a good heavyduty turnbuckle, inexpensive and works well.
Old Jan 24, 2003 | 05:13 AM
SuperchargedRS's Avatar
Car: Camaro of course
I heard that a engine brace such as the one in the pic will cause you ride to be ruffer, and shorten the life of you car??? I might get one but are these tings TRUE / FALSE????
Old Jan 26, 2003 | 12:41 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
i had one on my RX-7, worked very very well...when you would drop gears you would feel a huge difference instead of the engine turning it would put the power to the ground...its like having a broken trans mount then fixing it...the difference, other then the clunking on the floorpan...
Old Jan 29, 2003 | 09:37 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
I would only worry about how the frame would fare over time since the motor would now be playing tug of war on the "wanna be" unibody frame rail if you install a turnbuckle attaching the motor to the frame.
If it is engine movement that you want to eliminate then solid or urethane mounts on the motor and trans would be the way to go in my book.
Old Jan 30, 2003 | 01:29 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
look at a nascar engine bay. the whole thing is basically an engine brace.
Terrell351
Jun 13, 2021 01:13 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
NBrehm
Aug 5, 2015 07:57 PM
