Why do some A-arms have end links for adjustment ?
Old Feb 24, 2003 | 07:44 PM
john8169's Avatar
On Probation
What adjustments are made form the end links on the A-arms ? and how much can they affect a novice or intermediate driver ?
Old Feb 24, 2003 | 10:23 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have only seen such things when you go to heim joints for the A-arm joints where they meet the subframe. It is constructed that way to facilitate installing and replacing the heim joints. You can use the adjustments in conjunction with upper strut mount movement to increase or decrease track width as well as change things like the camber curve and caster drastically. Aside from track width, those are things already adjustable with the existing setup so basically they just give you much more freedom with alignment adjustability.
IMO, with your stated driving ability, I would stay away from that sort of adjustment as I seriously doubt you (or most of us non-professional drivers) would be able to actually tune that adjustment to our benefits.
Old Feb 24, 2003 | 11:52 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
You can use very little rodended a-arm adjustments on non-coilover cars. The spring will start to misalign in the can and perch with conventional spring setups.
Old Feb 25, 2003 | 06:47 AM
john8169's Avatar
On Probation
AHHH, yes. That is all perfectly logical. thanks for the info.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Sep 4, 2015 07:57 AM
