Anyone know how much it costs to 4 link our cars?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Who's doing the work you or a shop are you buying the stuff to put on yourself or is the shop going to provide everything? Waay to many variables need more details. If you were to do it ALL yourself, I could maybe see $4-500 for all the metal, brackets, hemi's, nuts and bolts.
I guess the first thing I'd do is check around with some of the asphalt/dirt track guys as they probably know of local shops and or persons that build chasis and cages everyday so they'd more than have the knowledge to fab up a 4 link. around here some guys charge by the hour($30-40), some by the bend ($5), some time and material (whatever material costs that is what labor will be), it's one of those things you'll just have to ask around and talk with people to find a better deal.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since 4 linking a third gen usually requires doing a complete back half, I'd guess in the $2000-$3000 range to do everything. It might even be more. Depends on the shop and how much they have to do.
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i thought about doing that last week....but i didnt like the idea if cutting inside the car for a place to mount to top links, or not cutting anything and having like 2 inch links lol.
Car: '91 Camaro RS
Originally posted by NJITIROC
what is 4 linking?
what is 4 linking?
in a racing 4 link the links are usually mounted parallel, not with the top 2 further inboard than the bottom ones like in some factory setups.
i believe the 80's montes were setup like that
db057
Aug 11, 2015 10:11 PM
