Adjustable panhard length
Old May 3, 2003 | 12:21 AM
danoko's Avatar
Axle/Gears: 4.11 Ford 9"
Anybody have a minimum length of adjustable panhard bar? I need one that will adjust 2" shorter than stock.
I put a Ford 9" in and the stock bar is about 2" too long. They must've welded the bracket in the wrong location.
Dan
Old May 3, 2003 | 02:32 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is my adjustable Lakewood panhard and it is set maybe 1/4" shorter than stock.
If you took off the lock nut and screwed the end all the way in, it might give you 1.5" at the most., but then again, you could cut the bar to fit if you need to.
This bar was $90 at Jegs.com
Old May 3, 2003 | 03:22 AM
JPrevost's Avatar
Car: 91 Red Sled
That's a good price for the adjustable bar but I'd still go with Spohn's stuff. I like his quality and his products. Just thought I'd through in that plug.
Also zeph, remove those bump stops! If you've got the wheels and tires I think you have then you don't need the bump stops. Having the tires bottom out isn't as annoying as having the bump stops hit. I removed mine from the rear and it made a noticable difference in ride quality.
As for the length of the panhard, you could just cut and weld. That's what I would do for right now. Then get the parts to make your own panhard adjustable for the length you require. The materials really aren't that expensive.
Old May 3, 2003 | 03:27 AM
Zepher's Avatar
I've been meaning to remove the bumpstops, just keep forgetting about them. They look really close to the wheels too.
I chose the lakewood because of the price. At the time, I had $1,500 to spend and wanted to maximize my dollar.
$1500 doesn't go far when modding these cars.
Old May 3, 2003 | 05:40 AM
SteveSpohn's Avatar
We can make a panhard bar any length you need. Just call me with the c-c measurement you require.
Steve
Old May 3, 2003 | 02:01 PM
Zepher's Avatar
Hey Steve,
Can you make this modded bar? The blue one that is bent.
Old May 3, 2003 | 02:14 PM
MdFormula350's Avatar
wow alot of goodies under that car
isnt that a custom job, i remember going to some site where u could but one a while back, but it was in Japanese.
Old May 3, 2003 | 06:54 PM
SteveSpohn's Avatar
That blue bar doesn't follow stock routing. Got any pics that show the mount point on each end?
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
