Mean rattle in the rear
Old May 7, 2003 | 05:38 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Ok guys I know everyone has rattles but this one is driving me off a cliff. It sounds like it is comming from the rear wheel well on the passenger side and it sounds like straight metal on metal. I checked EVERY bolt i could find to see if it was loose and took off the caliper and all but that seemed fine. I was wondering if it could be something inside the rear? Any suggestions pleaaaseee maybe i'll throw in some money...maybe
later
Old May 7, 2003 | 05:52 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
is your exhaust touching anything?
Old May 7, 2003 | 05:58 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
It doesn't seem to be. This rattle sounds like there is a piece of metal hanging on the side of the car just dangling. Mean sound.
I'll be back later if you have any other solutions
Old May 7, 2003 | 06:01 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
spare tire or jack and wrench?
Old May 7, 2003 | 06:22 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
naa took all that stuff out...even took apart the plastic stuff for the interior all off so i could find it. keep em comming though thanks
Old May 7, 2003 | 06:37 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I had a rattle something like that and the top nut on the rear shock was loose. Cat guts loose indide
Auggie
Old May 7, 2003 | 09:44 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Broken shock tower?
Old May 7, 2003 | 10:03 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
heat shield for the gas tank? could a loose parhard bar bolt. the last one was the case for me in my 86'.
Old May 7, 2003 | 10:07 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
What do you mean in the shock tower? How is the easiest way to get to the gas tank strap bolts. Oh and also do you guys think it could be something in the rear?
Old May 7, 2003 | 10:30 PM
Auggie's Avatar
Well, I like the one about the panhard/track bar bolts. I also had loose lower control arm bolts.
Auggie
Old May 10, 2003 | 12:15 AM
Fcarguy's Avatar
Car: 88 IROC, 07 Corvette, 05 Tundra
Engine: V eights
Does it rattle all the time? only over bumps? at certain speeds?
Old May 10, 2003 | 02:09 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
check the LCA and sway bar bushings. You might have a loose or broken bushing.
Does it sound like a box of loose tools in the rear, or just a piece of metal rattling?
Old May 10, 2003 | 01:48 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I get big rattles over bumps when a control arm bolt is loose, also have had the top nut on my shock loosen before and sound real loose and rattly.
Old May 11, 2003 | 01:35 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
It's whenever it gets the chance to rattle. I mean sometimes its not as bad as other times but for the most part it is whenever there is a lot of vibration. My sway bar bushings aren't in the best condition could that be the problem?
hectre13
Dec 11, 2023 08:14 AM
xxx3man`
Sep 23, 2015 10:37 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
