front end clunk
Old Jun 9, 2003 | 08:18 PM
jon_volk's Avatar
front end clunk
when im driving and go over a bump theres a clunking noise coming from the front suspension. the car only has 79k on it so i doubt that is bushings. any ideas what this might be? its just usually a single solid thunk everytime i go over a bump.
Old Jun 9, 2003 | 08:38 PM
Spdfrk1990's Avatar
i use this alot when people say they have a font end clunk because it happened to me b4 but did u check the endlinks.
Old Jun 9, 2003 | 08:41 PM
jon_volk's Avatar
swaybar endlinks right?
Old Jun 9, 2003 | 08:43 PM
Spdfrk1990's Avatar
yeh
Old Jun 11, 2003 | 07:12 AM
jon_volk's Avatar
swaybar endlinks seem OK. When i grab the top and bottom of the wheel there is some play and a slight clunking noise but i wouldnt think it would be the ball joints at 79k miles could it?
Old Jun 11, 2003 | 07:47 AM
Spdfrk1990's Avatar
maybe or are your bearing tight, maybe the strut is just shot
Old Jun 12, 2003 | 11:15 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
does it make a clunk noise when u drive straight with no bumps, if it does then it might be that the struts are not tighten. My car made a clunking noise and it was the struts that wasn't tightened all the way
Old Jun 12, 2003 | 11:56 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
balljoints can definately be worn out at 79k miles
but i'm not saying that's what the clunk is... it's a good place to start
i replaced my worn out ball joints at 82k with some Moogs... it's a pita the first time you do it, but after one time it's no problem
Old Jun 16, 2003 | 05:41 PM
jon_volk's Avatar
found it, idler arm is TEH LOOSE...
oh well, coulda been worse. headin out to autozone now.
thanks.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
