backing plates interchangeable 9bolt to 10bolt?
Old Jul 11, 2003 | 06:06 PM
lunatic_magnet's Avatar
Car: 87 camaro
Transmission: 5-speed
i have a 9 bolt with PBR brakes in my 3rd gen. unfortunately i have 2.77's. i'd like to swap rears for a better ratio, my question is can i use the same PBR setup & backing plates on a 10 bolt?
i have a 10 bolt disc housing i can build up but it has the old iron calipers... blecch!
also, are 10 bolt disc axles the same as 10 bolt drum axles? i didnt think so but i thought i'd ask...
Old Jul 11, 2003 | 08:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, the backing plates are different.
The axles are the same, sometimes. Lots of the early drum axles have a flange that's too large (outer diameter) to fit inside the disc caliper. Most of the later ones are the same. If I knew the exact diameters I'd give them to you, but since I'm an idiot, I don't.
People will give up their spare reproductive parts for those 9-bolt PBR backing plates. Sell them, and get a couple dozen sets of the 10-bolt ones.
Old Jul 12, 2003 | 06:41 AM
Car: 87 camaro
thanks for the reply RB83L69. i have 2 10-bolt rears to play with (a 3.23 disc w/ bad spring pack and a 3.73 drum w/ bad bearings). i'm hoping i have the good axles in the drum rear and can get one of those SLP posi units to put one good rear together for myself.
its always good to have spare reproductive parts... i'm glad to know the asking price for those backing plates thanks again!
Old Jul 15, 2003 | 04:28 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
wanna get rid of your 9bolt?
Old Jul 15, 2003 | 05:52 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
They won't interchange, the bolt patterns are different. RB's right. A drum brake axle has a larger flange diameter than a disc axle, you'd have to massage it a bit to fit it. Best bet would be to swap axles.
Here's a thought: Find a 3.27 drum 9 bolt and swap the brakes over.
Ed
Old Jul 16, 2003 | 03:13 AM
Car: 87 camaro
dan, not yet my car still needs the drive wheels on the ground. i probably wont do anything with it until winter. you wouldnt want to ship it down there anyways... it would cost $200-$250 to ship.
thanks ed...
i am on the lookout for a different rear, just havent found one yet. i bought the one that is in the car now without knowing what it was (friends' parts car), i heged my bets that it was better than a 2.77 and it wasnt. it was still worth the money for the PBR's, old rear was a 2.77 iron caliper rear.
so the backing plates for disc-drum are interchangeable on a 9-bolt? not on a 10 bolt because the drum backing plates are welded on, right?
Old Jul 16, 2003 | 04:09 AM
ebmiller88's Avatar
Unless I'm out to lunch, yes they will bolt on. All 9 bolt axles are held in with the axle retainers unlike the 10 bolts and their C-clips. The 10 bolt backing plates are not welded on, they are held on with 2 bottom bolts and a clip up top that holds the wheel cylinder on.
Sent you a PM.
Ed
Old Jul 16, 2003 | 05:44 AM
Car: 87 camaro
*grumbles* someone told me 10 bolt drum backing plates were welded on... i should look at this stuff myself instead of believing what i hear i guess.
Old Jul 16, 2003 | 06:35 AM
ebmiller88's Avatar
A friend once told me: "Don't believe anything you hear and half of what you see."
Ed
Fronzizzle
Mar 18, 2019 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
