Traction in Reverse
Old Jul 14, 2003 | 11:29 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Traction in Reverse
Is their anything I can do to improve my traction in reverse without compremising my forward traction. I can't back up a steep hill on wet pavement, and gravel is even worse. Is all F-bodies like this. I know the way the rear end is set up it doesn't do much for reverse traction but there must be a way to improve it. I have found that sometimes pulling up the Ebrake a little helps. I am not slamming the gas down either, I am barely touching it. I ask because it took me an hour one time to back out of a buddies drive way which has a steep hill at the end and is gravel and it was raining, I finally had to turn it around in wet grass, that was even less fun. We had to push it.
I figure while I am working on the suspension I would try to help this.
Old Jul 14, 2003 | 10:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Traction in Reverse= Front Wheel Drive!!
Ed
Old Jul 14, 2003 | 10:49 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I've noticed that their is very little traction in reverse, but I'm not concerned with that. ^_^
I assume that a crossmember mounted aftermarket torque arm while helping forward traction would also help in reverse as well.
Old Jul 14, 2003 | 11:18 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Yea, I know but then again my old f150 has traction in reverse. I was thinking that a relocation mount would be best thing for it.
Old Jul 15, 2003 | 06:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No doubt you were spinning one wheel much more than the other....
Posi helps greatly in both forward and reverse.
Old Jul 15, 2003 | 11:49 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The car has the limited slip rear, and yes, I spin both when I get in this situation. Now if I am rolling I don't have a problem, its going from a dead stop to backing up on a hill.
Old Jul 15, 2003 | 12:17 PM
(BR)G-Machine's Avatar
This may sound stupid and sarcastic but- Stop doing burnouts!
But really, how are the rear tires? Are they more handling or wear oriented, because those generally are bad for low speed and wet traction.
The front wheel drive comment is tue, but it doesnt mean he will have the same traction as a front wheel drive in slipery condition because all front wheel drive cars are front engined as well. He would b the equivilant of a mid engine front wheel drive which is about as silly a design as they come.
Old Jul 15, 2003 | 12:28 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Oh well I was looking for suspension add ons or adjustments, I know tire type, weight distrbution etc will effect the traction. I am just trying to improve it slightly. I am guessing a relocation mount would be best thing for it. Anyone install one and notice better trackion in reverse. Before I fixed a air leak at the intake to t-body my car would spin when I let off the brakes, but it would sometimes idel at 1k.
I have only done 2 burnouts in the 5 years I have owned the car. Both times were a day before going to get new tires.
Old Jul 15, 2003 | 03:04 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
One of the biggest reasons taht you dont have traction in reverse is your differential. For our cars if it came with posi or even if you installed an aftermarket posi. You wont have reverse traction. The reason? our posis are only 1-way. They will only work with acceleration. But with deceleration or reversing it becomes an open posi. I've tried finding 2-way differentials for our cars but sadly came up with nothing. The only option if you want 2 way posi like power is a spool O_o and I'm guessing you wouldnt want that.
Old Jul 15, 2003 | 03:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's not right at all.
Our differentials are clutch type (or cones, which is merely a cone-shaped clutch). All they do is to clutch the axle to the carrier. Therefore they do not care whether power is applied in forward or reverse, it's all the same. It's not a ratchet.
Old Jul 15, 2003 | 05:48 PM
REVLIMIT's Avatar
Engine: Built L98
hmmm...after some reasearch I guess your right. I got some info mixed up and what not.
On a side note though...do you know anyone that makes 2 way diffs for our cars? Ones that work with both acceleration and deceleration?
Old Jul 15, 2003 | 06:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK, we'll let it slide, but just this once.... next time, you'll have to narfle the garthog!!!
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
