New Front Springs installed
Old Aug 24, 2003 | 05:52 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i just installed new springs on my 86 v6 firebird. seems to sit way to high now. allthough i have not yet re-conected the sway bar (note: i am driving a backup car, not driving the bird with no sway bar) it seems to almost have positive camber, the tires seem farther apart at the top then the bottom. is it possisble that i was sent the wrong springs? did they make different springs for the v8 models? i think i may hve a real problem here.
on the pluss side i did take it for a quick testdrive (with no sway bar, badd me) and i can go over 25mph speed bumps at like 43mph with no problem. and without catching air. annyway i will post some pics tomorow after i get the sway bar back on. hoping that will bring the car down a little.
BTW: the new springs raised the car about 5 inches. thats how bad the old ones were. i think they had been cut. they were also sagging bad.
Old Aug 24, 2003 | 05:58 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
check your isolators, and make sure you got the springs indexed correctly, if they aren't indexed properly, the front end will sit very high.
Old Aug 24, 2003 | 09:38 PM
laiky's Avatar
did you get V8 springs?
Old Aug 24, 2003 | 11:33 PM
Tibey's Avatar
Car: 1987 Chevy Camaro Z28
Engine: 305, 4bbl, A/C, T-Tops
Transmission: 700R4 4speed Automatic
Re: New Front Springs installed
Originally posted by Xophertony
"...BTW: the new springs raised the car about 5 inches. thats how bad the old ones were. i think they had been cut. they were also sagging bad."
Whoa! 5 inches? that's quite a difference! what brand springs did you get?
Old Aug 25, 2003 | 06:11 AM
Xophertony's Avatar
Axle/Gears: n/a
how do i know? those are the rubber thingies on the top right? they are possitioned as correctly as i can figure. and the bottom of the spring is the way the haynes camero manual said (thats right camero, not camero/firebird, just camero, wtf?)
Tibey
they are OEM GM springs, stock. i ordered from GMPartsDirect.com
Old Aug 26, 2003 | 01:00 PM
Steve89GTA's Avatar
I have a feeling you've installed fourth gen springs. Although, my first guess would be that the isolator isn't on the top of the spring correctly. Did you use the tape trick (tape the isolator to the spring) before installing it to ensure they don't move?
The bottom of the spring end of coil should be between the two drain holes as far as I remembe.r..
Old Aug 26, 2003 | 02:02 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
It's OK to drive without your sway bar Give the springs some time to settle. If they are in right you will probably be fine after a while. Do you have a pic of the way it sits now??
Old Aug 26, 2003 | 08:22 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
4th gen front springs will never fit into a 3rd gen. as laiky asked, did you get v8 springs? i can understand about a 3" rise going from very old to new springs. pics are here of a spring swap i did.
http://www.fl-thirdgen.org/frontspringswap.html
and yes when putting in new springs, the car will raise up and camber will be more positive as shown in the link above.
Old Aug 27, 2003 | 01:28 PM
billhelton's Avatar
Car: 85 Sport Coupe
Engine: 355ci
Transmission: TH-350
I just finished doing the same thing with my 85 V-8. I put new springs AND struts on the front, and new springs on the back. The ride height seems to be about like a 4X4, but I've been assured by "front-end specialists" that the height will settle down to what it's supposed to be.
For what it's worth, I was told by Advance Auto Parts that the only springs available now are the 1LE springs. I don't think so, but that's what they said.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
