Are stock springs progressive or linear?
Old Oct 22, 2003 | 11:57 PM
25THRSS's Avatar
Just as the title says, which are they?
Old Oct 23, 2003 | 12:10 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
linear
Old Oct 23, 2003 | 12:13 AM
25THRSS's Avatar
Both the front and rear?
Old Oct 23, 2003 | 12:14 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
believe so, could be wrong.
Old Oct 23, 2003 | 02:26 AM
CrazyHawaiian's Avatar
Car: too many ...
yup both front and rear are linear. IMHO progressive rate springs are a gimmik.
Old Oct 23, 2003 | 02:31 AM
25THRSS's Avatar
I dunno about a gimmic. They most likely do provide a smoother ride while cruising, but I agree they suck for all out handling. Too unpredictable for me. I will probably will be going with a good set of linear springs like hotchkis. Any other recommendations?
Old Oct 23, 2003 | 02:32 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i dunno, i have the eibach sportlines in my car, their progressive, they are a very nice performing spring. the ride will fool you, it rides VERY nice, it seems as if the springs are much more tame then stock but, then u hit a corner and the handling power is phenomenal. i love em glad i bought them. put in a set and never look back!
Old Oct 23, 2003 | 10:50 AM
Car: too many ...
I used to run Sportlines in my 91Z. I've also used the Pro-kit on my former 92 B4C. The sloppy spring rate while driving straight on the freeway would cause my front to bottom out if I hit a bump that was too big. It wasnt as bad with the Pro-Kit because the ride height was a little higher allowing me more suspension travel. But I still had issues (with the stock 16's even). Now I run linear rate springs and I feel a huge difference. The ride is stiffer, but the car is a lot more agile. The sloppy feeling of the progressive rate is gone. No more body roll and the car never bottoms out, even over the biggest bump. Comparing my linear setup to the old progressive setup I have to say the progressive setup gets the thumbs down. For someone who wants all out handling capabilities I dont think they are a good choice. I call it a gimmik because the sales pitch leads you to believe they are the best, but in reality they are sloppy when compared to a stiffer linear rate spring.
But I tell you what, if you could actually choose what spring rates to use in the progressive rate spring then I would not be bashing them at all. I think the rates they chose are too soft for our car.
Old Oct 23, 2003 | 11:54 AM
91Z28-350's Avatar
I have to agree with the last post. The Pro-Kit is a bit soft and sloppy. It's OK around the street, but there's a bit too much movement at times. It is a step up over the stock springs, IMHO, but a higher rate linear spring would be better.
Old Oct 23, 2003 | 12:15 PM
iroc22's Avatar
Yeah progressive springs usually do what they're supposed to but it's the hype from the companies that kind of let you down.
Old Oct 23, 2003 | 12:25 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
So hotchkis springs are linear front and rear? Who else makes a stiff linear set with a slight drop?
Old Oct 23, 2003 | 01:32 PM
laiky's Avatar
CH hit the nail on the head! i agree totally.
Old Oct 23, 2003 | 02:05 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
def. CH summed up most of our views.
another note . . . progressive coils are a little less 'predictable' which is the ultimate goal of really going fast, you need the car to react exactly the same, on every corner. otherwise you won't be able to learn how to push your car to the limit.
Old Oct 23, 2003 | 09:37 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
All I'll say is- I run progressive rear springs, but linear fronts. Gives the *** end a better feel for me and gives better squat in the corner until it locks down to the stiffer rate to prevent bottoming out. They are fine as long as you control them with high rebound damper.
Old Oct 24, 2003 | 03:29 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hawaiian,
what kind of springrates you have at rear,and how much drop?
Jari
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
