4th gen rear brakes... prop valve needed?
Car: Check The Sig
With the rear, is it a MUST to put in a prop valve or is it just recomended, but not really need? I have drums, and I wana just swap out the whole rear with a 4th gen's and wanted to know if its a must to put a prop valve in. If so, about where do you think it should go? closer to the rear, or closer to the mast. cyl? Thanks
Alex
Alex
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there Al. It's not necessarily a "must" but the factory manual says it needs to be changed, esp on the '88-older cars, like your '87. I do know there are guys using their stockers and hving no problems, I just changed mine to be ****. I'd say test it and see how you like it before you swap it out.
Ed
Ed
Car: Check The Sig
Ed
Ed
thanks man. Im more talking about an inline prop valve like one you can grab out of summit. I also heard about cars not needing it, but if need be, ill do it.
She's fine...getting REAL sick of the car stuff...he heh.
OK, in line adj prop, I get it. I think they are better and give more control so go for it. They don't fit my needs so I pass.
Ed
Ed
Car: Check The Sig
Ed
Ed
Ill give it a try, now just need to stea...i mean "find" a 4th gen rear... humm. Junkyard time.
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Im running the stock 86 prop valve for an 86 with a 4th gen rear. The brakes work fine as is but I would like a little more rear breaking... so its not a must but if your like me you will want to swap it or just go with an adjustable.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
