Suspension and Brake upgrade advice
Old Nov 9, 2003 | 10:15 PM
steve's Z28's Avatar
I own a 1991 Chevrolet Camaro Z28 with a 5.7 tpi motor, Tockico suspension setup (frt struts and rear shocks-aftermarket stock replacements), stock coilsprings, and stock brakes-front single piston calipers and rear drums. My future plans for this car is to upgrade the brake system and possibly lower it. I am looking for a braking system that has the best stopping power. I plan to upgrade the brakes to make my car safer. What changes need to be done on the car? Do the spindles have to be changed? What brake kit can I buy to retain my stock 16" alloy wheels? I would appreciate detailed info on the brake components such as rotor diameter, backspacing and material,etc. I also have plans on lowering my car. Right now it is at stock ride height. I have read on other threads that modifications have to be done such as relocating the rear lower control arm brackets and replacing the panhard rod. I plan on purchasing the Tockico brand coils that lowers the car 1.25 inches. Do I have to relocate the lower control arm brackets? What other modifications have to be done?
Old Nov 10, 2003 | 06:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
http://www.spohn.net/product.cfm?productid=1453
there is your brake upgrade.
to correct the geomitry from lowering, you will want and adjustable panhard and LCA relocation brackets. they are not 'nescesary' as in you car won't fall apart if you don't do it, but it will correct the suspension geomitry from lowering.
Old Nov 10, 2003 | 10:12 PM
Hey thanks for the picture. Those Wilwood pads have a lot of material on them. Would you happen to know if Wilwood makes a rear disc brake kit? I'd appreciate it.
Old Nov 10, 2003 | 10:39 PM
Old Nov 11, 2003 | 02:38 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
One that website, Spohn says you need to have the standard spindles modified, you can do it yourself or have them do it. What kind of modifications are necessary??
Old Nov 11, 2003 | 06:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you have to cut of some of the mounting point for the stock spindles. i beleive it is the same mod as the 1le upgrade, if you do a search for modifing your spindles for 1le brakes, you will see what needs to be done.
Old Nov 11, 2003 | 06:55 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
Thanks for the info, those are some sweet brakes, I don't know if I could part with $1,500 for them, though. I'd rather put that into going faster
Old Nov 11, 2003 | 06:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
price out ANY brake upgrade, 1500 bones for that is a STEAL.
Old Nov 11, 2003 | 07:28 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
Don't get me wrong, they are a great deal compared to most other brake upgrades out there, I just think they are all way too expensive. Not bashing the manufacturers or the distributors, just a personal opinion. If I was to buy a brake kit, these would probably be them.
Old Nov 11, 2003 | 07:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
ohhh i'm sorry, by your post asking about brake upgrades, i assumed you actualy wanted to spend money on upgrading brakes.
Old Nov 11, 2003 | 08:11 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Come on Dewey...he's asking for advice here....
I'm a supporter of Spohn too but there's other options.
Crew, look into the C4, C5, or LS1 brake upgrades as well as the factory 1LE kit that Steve sells. The Wilwoods are a FINE system but I couldn't drop that for brakes either, those are beyond what I would need. For less than $600, you can put yourself together either the C4, C5, or LS1 brakes and have excellent stopping power.
Do a search for "brake upgrades" and see what you get.
Ed
Old Nov 11, 2003 | 08:15 AM
ebmiller88's Avatar
I'd rather put that [$1500] into going faster
It seems a LOT of guys have this in mind and will totally overlook their braking system...how often do you see posts like: "My car pulls to the right." or "My car won't stop!!"
Going fast is good, but stopping is a necessary function also. Don't overlook your brakes. Even a good working stock system will save your ***, and will only cost around $200 to get it working up to par.
Ed
Old Nov 11, 2003 | 08:23 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
I totally agree, that is why I want a MINOR upgrade for my braking system, so that I have enough power to stop when I need to. Dewey, spending money on brakes, and spending $1,595 on FRONT brakes, is two totally different things.
Can't you understand that maybe I don't need all that braking power?
Old Nov 11, 2003 | 08:26 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
Thank you, ebmiller, for the giving me the advice I was looking for without flaming me.
Old Nov 11, 2003 | 08:32 AM
ebmiller88's Avatar
[Insert SC accent]
I hear tell Ol' Steve's a-been a-workin' on one o' them there kits as we speak.
Ed
Old Nov 11, 2003 | 07:04 PM
91Z28-350's Avatar
spill, please...
Old Nov 12, 2003 | 05:39 AM
ebmiller88's Avatar
IIRC, Alloy posted a bit of info in the "Spohn 13" brake kit" thread.
Ed
Old Nov 12, 2003 | 07:31 AM
CrazyHawaiian's Avatar
Car: too many ...
n/m
Old Nov 12, 2003 | 07:33 AM
Car: too many ...
Re: Suspension and Brake upgrade advice
n/m
Old Nov 12, 2003 | 07:34 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Originally posted by CrazyHawaiian
[B]The C4 upgrade would also be good, but I'm not 100% positive it will work with the stock 16's.
they fit under the stock 15" wheels.
The C5, LS1, and Spohn NASCAR kit perform very, very well, but require 17" wheels or bigger, so not the right choice for you.
the spohn wilwood kit fits under 16" camaro wheels.
Old Nov 12, 2003 | 07:42 AM
crewdawg16's Avatar
Car: '86 Trans Am
Engine: LB9
CrazyHawaiian, I am not Steve's Z28, and I did not ever say what you quoted, in fact, if you look at that post, you quoted two entirely different people.
Old Nov 12, 2003 | 09:34 AM
ebmiller88's Avatar
Yep, looks like Stev dropped out of the topic.
The C4 upgrade would also be good, but I'm not 100% positive it will work with the stock 16's. The C5, LS1, and Spohn NASCAR kit perform very, very well, but require 17" wheels or bigger, so not the right choice for you.
Both the C4 and LS1 front brakes fit under 16" wheels, as stated by Dewey. Also, the C4 kit will be closer to the Baer kit as it also uses a hub/rotor combo. The 1LE kit doesn't use a hub/rotor combo and you will have to mess with bearings when you have to swap rotors.
Ed
Old Nov 14, 2003 | 09:09 PM
Has anyone used a Baer Brake, Aerospace, or Stainless Steel Brake Corp. brand brake system on their car? I read on Baer's catalog that their Track System might fit a 16" OEM 1991 Camaro wheels. Is this true to anyone who has installed them? Looks like there is lots of choices and I will have to research carefully.
Old Nov 14, 2003 | 09:26 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Well the brake system Dewey showed you definately fits under 16" 1990 to 1992 camaro wheels. I know because I'm the designer and builder of those brake systems for Spohn. And I have personally tried the 90 to 92 wheels on my car equipped with the system. They will definately fit without any interference at all.
Old Nov 14, 2003 | 09:56 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
If you want a budget brake upgrade I don't see how you can pass up the C4, LS1, or C5 conversions. I'm in the process of building the LS1 upgrade for my car. I have my setup about ready to go on the car and have spent all of $210. The LS1 setup uses 2 piston aluminum calipers clamping 12" rotors. Of course for that price I had to do all the cutting/fab work myself which suits me just fine. If you do not have the tools or the ability to do the work yourself it would cost more.
Old Nov 14, 2003 | 10:23 PM
alloy's Avatar
Car: 87 IROC-Z28
Well think of budget this way.
steve's Z28 already has 16" wheels. If he spends $1200 to $1500 to go to 17" wheels and tires to clear the C5 brakes, does that still make the C5 setup a budget system in his case? And for that matter any brake system that requires you buy 17" wheels and tires knocks it out of the "budget upgrade" range.
Old Dec 7, 2003 | 04:44 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
$200 for LS1 brakes. Any idea how much all this cutting, fabricating etc will cost for those of us who do not have lathes, drill presses, etc. in our garage?
Old Dec 7, 2003 | 01:02 PM
iroctpis's Avatar
C4's
Here is the C4 brake kit I got .
https://www.thirdgen.org/techbb2/sho...hreadid=199076
Old Dec 7, 2003 | 01:03 PM
ebmiller88's Avatar
It all depends on what you have done and who does it. Like Chuck, I do all my own work so mine is free. Alloy (Dan) is a machinist so he may be able do give you an estimate on what shop labor will cost.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Aug 28, 2015 05:57 AM
