Break Line HELL
Old Nov 29, 2003 | 05:11 PM
CamaroRS91x's Avatar
Break Line HELL
wow.....
as I'm typing this I'm about to go through a nervous breakdown.
Yesterday my friend and I were driving, and all the sudden my breaks went right down to the floor. Luckily, nothing was hurt. I pulled into a parking lot and left it there overnight. Today, I took off the front passanger wheel and discovered that my break line had a hole in it. So I went to autozone, and he gave me a new line. I went to put it on and the end that hooks to the steel hose broke off while loosening. The steel hose, at this point, has nothing attached and is just sitting there under my wheelwell. While panicing, I went back to autozone and the guy helpfully told me that I cut off the end of the steel hose, and connect it to the new brake line. He gave me this little tiny gold threaded screw/connector thing. So I went back, did what he said by sliding the connector over the open-ended steel hose, and connecting it to the new brake line. and after 3 hours of swearing kicking and all that, and I had my friend pump the breaks.....break fluid leaked everywhere at the spot that I have the connector. I almost went crazy, seeing as I was outside in freezing weather for 4 hours fixing this. What are my options now? Any idea's? thanks
Old Nov 29, 2003 | 06:08 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Well honestly the safest thing to do is replace the hard line. It isn't very long. Just make sure you bleed the master cyl. and the calipers. I wouldn't mess with rigging your brakes. You could end up killing yourself or others on the road.
Old Nov 29, 2003 | 09:37 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
ummmm......did you flare the steel line?
dont talk to people from autozone....just slap them
Old Nov 29, 2003 | 10:22 PM
hey thanks guys
383....he gave me a tool that you put in the middle of the hole to expand it to make a 'mushroom' of the end of the metal hose. is this what you mean by flare? sorry I'm a newbie.
Where could I get a new hard line? And how would I go about slapping this on there? Thanks
Old Nov 29, 2003 | 10:46 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
flare and mushroom same thing.
You can try your local autozone dealer or try classic industry.
Old Nov 29, 2003 | 11:42 PM
What I'm worried about is how long of steel line I need......and how I'd bend it... also any connectors I need to put it back to stock?
Old Nov 30, 2003 | 12:04 AM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
flaring the hard line on my 91 Z was EXTREMELY difficult. It's a 6mm steel line, which looks to be extra thick (of course!). I'm guessing he gave you a double flare kit - you _really_ have to crank that flare tool down! We had you use a deep socket over the tools handle with an extension attached to it to get it turned enough to use a coupler (the gold thing). Even then, getting the flare centered properly was NASTY!
Good luck - please do it right and be safe! Do _not_ let the autozone guy offer you compression fittings...
Old Nov 30, 2003 | 12:51 AM
Car: '91 Camaro RS
its just tough to do if you've never done it before.....and if you dont get the flare nice and smooth and large enough it will leak no matter what you do......somtimes you have to chop the piece of the end and flare it again
Old Nov 30, 2003 | 05:59 AM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
if it is a 91 like his sig says that should be an ISO or (bubble) flare.
double flare will not work.my 88 had the metric flare(ISO).
just a thought
Old Nov 30, 2003 | 08:34 AM
Car: '91 Camaro RS
your splicing a union into the line to repair a section thats missing, you can use a standard flare on both ends which is easier to make....as long as you use the correct fittings with it
Old Nov 30, 2003 | 04:59 PM
No4NJunk's Avatar
Just replace the hard line. I was under the impression that they sold prebent lines with fittings already installed on them. I've installed them before. If not then here's a quick link that will explain how to double flare the ends. (*I was too lazy to write ).
How to flare brake line
Don't forget to bleed the master cyl. I'll explain if needed.
Old Nov 30, 2003 | 06:51 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
lol, prolly the best piece of advice ive heard on the board
Old Nov 30, 2003 | 07:05 PM
Car: '91 Camaro RS
lol well ya just gotta keep it real.....my favorite auto zone incident is trying to buy wheel studs.
i was like "i need 10 1/2" 20 threaded wheel studs 3-1/2" long"
auto zone honda kid reply - "what year is it?"
no, it doesnt work like that
just give me that size wheel stud
auto zone: "i cant look them up if i dont know what kind of car it is"
I know where they are in the back, want me to show you?
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
earlpote
Sep 12, 2015 11:55 AM
TBRays98
Sep 6, 2015 05:05 PM
dimented24x7
Sep 6, 2015 03:51 PM
