Rims - 16" vs. 17" - not a looks question
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
If everything else is equal, how much more harsh is the ride on a 17" rim vs on a 16" rim? Both would have the appropriate size tire to maintain the same overall diameter, so it's the sidewall that would change. Lets also assume the same kind (or brand/model) of tire, just different size. Significant difference in ride quality or not?
K
K
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
My 40-series tires made for a much harsher ride than my old 255/50/16s. If youre concerned with ride quality, Id probably stick with the 16s.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by MdFormula350
umm when i went with newer rims the car liked to "suck" into potholes, and liked to move around left or right alittle more on those roads that are not straight and have crowns.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
since when have thirdgens had ride quality
that'll be the day.
Car: '89 IROC-Z
Aw, don't give in that quickly!! With some thoughtful tuning, I think you could get a really nice riding 3rd gen - if you wanted to. Just seems like with all the chassis and suspension upgrades or improvments out there and with the huge variety in wheels/meats there have to be some combinations that work significantly better than others to improve ride.
I was mainly wondering how much the wheel size affects ride quality........
I went from 215/50r15 front and 275/50r15 rear to 275/40r17 all the way around and noticed very minimal increase in ride harshness. It rides a little rough to begin with... 16" should be less dramatic if noticable at all.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
When I went from 245/50s to my current 17s with 245/40 front and 285/40 out back, I only noticed a rougher ride in areas that were already pretty rough. Train tracks suck. Road work areas suck. Other than that, I have really enjoyed the added grip of the stickier, less flexing tyres...
Djmathis123
Sep 29, 2015 01:36 AM
