Slop on end links
Old Jan 20, 2004 | 04:40 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Slop on end links
I was under my car and discovered 1/2" or more of slop between the front sway bar and the end links. Is this supposed to be tight or sloppy. The end of the sway bar dosen't touch the bushings on the end links. Should I replace the end links, if so do you tighten to a spec or just yank away.
I was also considering changing the stock sway bar and bushings at the same time. Are greaseable bushings enough of a replacement or should I replace the sway bar at the same time ? Not building a race car, just a nice Sunday car that handles, sounds and looks good.
Thanks,
Old Jan 20, 2004 | 06:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
see if you can tighten properly, and if it holds
if not replace the endlinks.
Old Jan 20, 2004 | 09:25 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
More info needed.
Dewey,
Do I just tighten all the way to the bushing, as far as I can?
Old Jan 20, 2004 | 09:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
easy way to do it....
tighten it down until it is it smooshes the bushing out to the same diamiter as the little cups that fit over the bushings.
(i hope that makes sense, it is about the best way i can descibe it)
i am sure you could also find torque specs for them somewhere, but i usualy just tighten them down until the booshing as cup match.
Old Jan 20, 2004 | 09:43 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Thanks, yes that makes sense.
Do you recommend the new sway bar bushings for the car. The sway bar and bushings are original. The bushing around the sway bar looks degraded.
This message board is real helpful, so much easy info for us rookies!
Old Jan 20, 2004 | 09:53 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i would up put on some poly endlinks. you see a nice improvement going from GOOD rubber, to poly, imagine going from bad rubber, to poly
Old Jan 20, 2004 | 09:55 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Thanks again,
won't bother you any more, for now anyway.
Old Jan 20, 2004 | 09:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
its fine, thats what these boards are for
1992rs/ss
Jan 31, 2025 05:10 PM
Amillionoh7
May 24, 2020 08:01 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
