caster/camber plates
Old Jan 30, 2004 | 08:44 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Does anyone make adjustable caster/camber plates for our cars? I want a set cause I'm gonna use my Camaro as a daily driver and track car and I dont wanna have to take my car to the alignment shop every weekend.
Old Jan 31, 2004 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take a peek at this link:
https://www.thirdgen.org/techbb2/sho...ight=sway+bars
JamesC
Old Jan 31, 2004 | 11:31 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
um... That is very very useful for some other stuff I was wondering about. Thanx.
But, I didnt see anything about caster/camber plates.
Old Jan 31, 2004 | 11:54 AM
JamesC's Avatar
Well, @#%@#%^$%$%# !!!! Here's what I intended to post:
http://www.spohn.net/category.cfm?categoryid=1071
Sorry about that,
JamesC
Old Jan 31, 2004 | 12:52 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
hehe. I figured somethin like. Thanx man.
Old Jan 31, 2004 | 05:02 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i know what he's talkin about , i saw them not too long ago i cant remeber if it was in a magazine or one the web. give me awhile, i think it was in a magazine and well i got tons of GM magazines here to look thru but i think it might have been in a GM hi-tech mag.
Old Feb 2, 2004 | 07:18 AM
AFTERMIDNIGHT's Avatar
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
i think ground control sells some too.
Old Feb 6, 2004 | 10:57 PM
Ratchet's Avatar
We had kinda the same Idea. You know a street car that can carve corners do the autocross, circle track whatever. So We made up these plates. When I first posted the pictures of them didn't get many responses. Not sure if the picture showed you enough about the idea. So here is the original picture.
And here are a couple of the installation.
Not too expensive to make just took a little time. Oh yeah these are dual purpose along with allowing for quick accurate adjustment of Caster and Camber they also raise the mounting point for the Strut by 1" thereby allowing for proper travel of the struts when you lower your car.
Ric
Old Feb 7, 2004 | 06:07 PM
CrazyHawaiian's Avatar
Car: too many ...
Looks like a very good product!!
Old Feb 23, 2004 | 09:30 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Sweet. Ratchet, you just make those up, or you have a company?
If you aren't makin them to sell, do you have any plans for them drawn up? I know some people that can cut up custom stuff, they just need blueprints or whatever
If you are, how much would it cost from you or to have you make a set for me?
Thanx,
Chris
Old Feb 24, 2004 | 12:05 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Sweet! You've got my interest.
Old Feb 24, 2004 | 02:16 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I remember there was this one company that was supposed to make some camber/caster plates. They said they'd call me when they finished production...that was about...2 months ago or so O_o...I don't remember what the company was now though. I guess htey either 1) didnt make them or 2) forgot about my ***. Doesnt really matter to me though...the stock plates give enough camber/caster for now. If anything I'll just pick up that set from Spohn instead.
Old Feb 24, 2004 | 03:01 PM
drain89's Avatar
Revlimit,
I think you're talking about J&M. They did the same thing to me. Oh well, I have other choices.
I'll go with the Alloy/Spohn ones or the Ground Control ones combined with something like these. I think that would be the best setup, actually.
Old Feb 25, 2004 | 05:12 PM
Ratchet's Avatar
Sorry no prints. I just made them up out of 1 inch thick aluminum the screw adjuster in the side are 1/2 capscrews and the mounts that are welded to the strut tower are 1 inch square tubing modified so that the capscrew can slide with the strut mount and still adjust it. as the the profile of the plate i just traced the strut mount and left a couple of flat areas where the adjuster bolts go thru. the adjuster holes are tapped all the way thru the aluminum to allow for enough travel. the stock mount is attache to the aluminum plate with two 1/4 20 flat head cap screws. Not rocket science just cut and try.
Good luck.
Ric
Old Feb 25, 2004 | 05:20 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
there are pictures of my Caster/Camber plates in the link in the sig for the 87 T/A
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
