Harsh? Soft? Or somewhere in between?
Old Feb 18, 2004 | 02:56 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Well, I have finally made most of the decisions I am going to make on the buildup of my Camaro's Suspension and I wanted to get everyone's opinion on the ride quality. This will mainly be a weekend warrior and used for trips to Vegas. Also it's a vert so no trips down the track, however it will be putting a lot of power to the pavement so I tried to keep all that in mind. Here's the list:
Spohn
LCA Reloc Brackets
LCA Tubular / Poly Bushings - Chromemoly
LCA Mounting Hardware Kit
Panhard - Tubular / Poly - Chromemoly
Panhard Bar Mounting Kit
Adj Torque Arm – Rear Mounted- Moly Spherical End - Chromemoly
Torque Arm Rear Mounting Kit
Billet Upper Strut Mounts
Koni "Reds" S & S Package
Poly Transmission Mount
Performance Suspension Technology (p-s-t.com)
Moog Front Replacement springs
Moog Rear Replacement springs
front end kit
Inner tie rod ends
Adjustment sleeves
Centerlink
TDS
Alston SFC’s
Wonderbar
Front (36mm) Sway Bar Bushing (TDS / Red)
Rear (24mm) Sway Bar Bushing (TDS / Red)
1LE end link kit (4) (2 per bar / TDS)
Internet / Mail Order
AJE Tubular K member (jegs)
AJE Spring Perches
Moog Idler Arm
Already Have
Hotchkiss STB
36/24 Sway Bars
As you can see I am nearly replacing everything. I would like a comfortable ride that I could drive everyday, but I can deal with a lot as well. I know there is going to be a trade off, but I just don't want the above to be as stiff as a board on every bump.
James
Old Feb 18, 2004 | 05:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well performance and comfortable don't go together. If you really do all of that stuff you will be very happy with the performace of your car. it will be a real performer. However, because of all the stuff you are taking out all of the dampening characterisitcs of your stock rubber bushings and stamped parts. They allow for a smooth and soft ride but now you are going to trasmit more vibrations and stuff right into the car. It will ride rough but shouldn't rattle your teeth out.
Old Feb 18, 2004 | 11:02 PM
Engine: 355
Well, that's one reason I went with Moog stock Ws6 springs. I wanted stock height so that I didn't bottom out. I was going to go with the prokit. It would look cool, but I was very worried, wit hthat suspension that I would be in trouble with any kind of normal driving
Old Feb 18, 2004 | 11:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Don't fear the lowering springs. The pro kit would make your set-up perform even better. You will only bottom out on the same things that you do now with your stock stuff.
Old Feb 19, 2004 | 01:59 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
OR LESS! My springs and struts/shocks were pretty shot and sometimes I would bottom out on the freeway and just during normal driving. Now with the prokit, I feel every groove on the road, but without the scraping sound Here in So. Cal. our roads are not as bad as other places, although some can be pretty rough (potholes and such). Personally, I like the feeling. I think the issue of bottoming out because of lowering springs shouldn't necessarily be a concern. Unless of course u run the risks of frequent tow truck visits, in which case your concerns would be in other places.
Good luck, Efrain.
Old Feb 19, 2004 | 02:39 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Are those the poly/poly LCA and panhard your looking at? If so, I would recommend geting the poly/rod end combo. Much better from a performance standpoint, and IMHO wont offer a harsher ride over the poly/poly.
Old Feb 19, 2004 | 03:20 AM
CrazyHawaiian's Avatar
Car: too many ...
I wouldnt think you'd need the AJE Spring Perches if you are going to use stock height replacement springs. You also wont need the Billet Strut Mounts. These usually have a raised top which will provide more suspension travel for the struts on a lowered car. Since you are staying stock ride height, you can save some $$ and go with something like the Spohn Upper Strut Mount Package.
Old Feb 19, 2004 | 10:34 AM
Engine: 355
Frains90RS
Something in my car seems brand new (I bought it in 1998 and it has sat while I restore it little by little) but I have more ground clearance than my buddies 92 RS and a lot more wheel clearance. Though I rub real bad, but that is another post...
I really want to gowith the prokit, I think it will give the car a much better stance and will look normal.
Justins86bird
Do you mean I should go with these:
Lower Control Arms - Adj. Spherical Rod Ended
Instead of these?
Lower Control Arms - Tubular w/ Poly
I trust your guys opinions and do not mind spending the extra money.
CrazyHawaiian
Jegs, I believe said you have to have the spring perches if you are using stock height springs. However, if I was going with the prokit, would I than not need them? As far as the strut mounts go I think they give form and function. I like the way they look as well, but if they will make the ride that much harsher, I will stick with stock
Old Feb 19, 2004 | 05:03 PM
Car: too many ...
Well I think I'm talking about different spring perches than the ones you are talking about. I'm thinking the spring perches you are getting work in conjunction with the tubular k-member to provide the stock style spring / strut configuration. If this is the case, then yes you will want the AJE spring perches. The spring perches I was talking about are adjustable pieces that work in conjunction with the spring itself. These are usually used with shorter springs, and adjustments made to the perches to give you the desired ride height. If you are not talking about the adjustable perches (or sometimes called buckets), then disregard what I said.
As for the strut mounts, make sure you inquire about using them with stock height springs. The extra inch of strut travel provided by the raised top might not work with a stock ride height. This extra inch of travel is intended for lowered cars, as to retain the full strut travel. If the car is not lowered, the stock struts might not be long enough (or be able to extend enough) to be installed with the raised tops. Just make sure to ask about it before ordering.
Good Luck!!
Old Feb 19, 2004 | 06:56 PM
Frains90RS
Justins86bird
Instead of these?
You can get those, but I ment these
http://www.spohn.net/product.cfm?productid=1294
Dont get the poly/poly ones.
Old Feb 20, 2004 | 10:08 AM
Engine: 355
Ok, just so I am clear, if I was going to go with the Eibach prokit, I SHOULD get the Spohn strut mounts to allow them to properly do their job.
Also the spring perches that jegs says you have to have with the K member, I will still need those with the prokit as well, right?
I am going to be ordering very soon, so I just want to make sure that I have got everything worked out ahead of time.
Old Feb 20, 2004 | 11:34 AM
You can get the mounts if you like. They are better then the stockers but aren't necessary.
Old Feb 23, 2004 | 05:24 PM
Engine: 355
Quick question. This is for two control arms right? Not one?
customblackbird
Aug 15, 2021 10:16 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1992Z28!
Nov 19, 2015 07:33 AM
jbates346
Sep 22, 2015 05:22 AM
