How to measure for clearance
Old Mar 26, 2004 | 06:10 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Of my pipes. I keep wanting to put air ride on here and know its gonna be awhile so now i just want to put maybe 2" drop springs on her. Talking to flynlow he has the dropzone coils with a 3" exhaust and has no problems. What i'm worried about is the exhaust going over the axle looks liek it would be crushed if the car was slammed 2". But i loaded up some crap and peopel in the back and managed to get a 2" lower with the weight and then bounced the back end and it didnt seem to hit the pipe. Is there any for sure way to measure the travel if my pipe will get smoked or if it will be ok to lower it. Thanks
Old Mar 26, 2004 | 08:20 PM
Kandied91z's Avatar
i'm running 4"
Old Mar 26, 2004 | 09:03 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'm running 3" an am lowered 1.5" in the rear. You could saw your bumpstops off, bottom out the rear and you wont crush the pipe...well at least I havn't
Old Mar 27, 2004 | 01:40 AM
Kandied91z's Avatar
i also no longer have my bumpstops but it was because of rim size rather then anything else. i ran a year with it in stock form and no issues with 4"
Old Mar 30, 2004 | 09:58 PM
Car: 91 Camaro RS
Engine: TBI
So what would cuttign the bump stops out do;.
Right now i'm looking at a 2" drop with my 3" pipe and it wont crush the pipe is what i'm hearing. If so springs get ordered right after my fan
Old Mar 31, 2004 | 06:48 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
cutting the bumpstops is just going to allow you to have some suspension travel. Otherwise with a 2" drop you're not going to have any cause you'll be sitting on them.
Old Mar 31, 2004 | 08:05 PM
Car: 91 Camaro RS
Engine: TBI
I havent really got a good luck at the setup but how did you go about cutting off the bumpstops and where are they?
Old Apr 1, 2004 | 07:30 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I used a grinder to cut the bumpstops. When you do cut them make sure you still cut them on an angle like they were originally designed. Yer not cutting them totally off. If you have to totally remove them to get 1" of clearance then yer too low and yer screwed.
The front bumpstops are located on the front part of the lower control arm. The rear bumpstops are located on the uni-body directly over the axle on both sides.
I would install the springs and let your car down to see how much clearance you have and then cut them after so you have at least 1" of clearance(which really isn't enough for city driving but it's a bare minimum). Don't want to cut too much at the same time!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Jul 1, 2018 04:12 PM
91 SrS
Oct 7, 2015 04:32 PM
AUZ28
Oct 3, 2015 06:28 PM
