line lock tips needed
Old May 20, 2004 | 05:48 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi probabely all of you guys knows how a line lock work. You need to push the brake pedal down and hold the switch and as soon as you leave the switch the gar goes. My at my local dragway 1/8 racetrack we are not alowded to do a stand up, dos'nt matter how long your burn is as soon as your car is mooving. i know with rear drum disk you just push the 2 pedal to the floor but with my rear disk its impossible. is it possible to put my line lock in the rear brake line but IN in OUT and OUT in IN?
to let me brake only with the front brake with the pedal?
Old May 21, 2004 | 06:34 AM
ede's Avatar
ede
not exactily sure what you said or ask, but i'll try. yes a line lock can be set up to work at either end of your car.
Old May 21, 2004 | 07:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: line lock tips needed
uhh, could you rephrase the question?
huh?
umm... the in and out are still the same way.. the pressure comes from the master cyl no matter if its front or rear brakes.
are you asking about blocking off the rear line so you can modulate the front brakes without using the rears??
Old May 21, 2004 | 02:13 PM
FOX-GTA_89's Avatar
yes kid of i want to smoke wile im touching the brake and be able to move!
Old May 21, 2004 | 03:14 PM
ede's Avatar
ede
there's a preview icon right next to submit use it or quit posting and try using words you can spell or looking the spelling up before you type them
Old May 21, 2004 | 03:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh, dont be so harsh dude.. look where hes from.. theres a damn good chance that english isnt even his first language.
in anycase, ive never hooked up a line lock backwards like that, so i dont know.
it sounds like it could work though.
Old May 21, 2004 | 03:21 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
intead of a line lock, you could try a brake proportioning valve to effectively disable the rear brakes, but have fun stopping.
Old May 21, 2004 | 03:22 PM
ede's Avatar
ede
i considered that but his profile looks to be filled out and spelled pretty well. i know i'm not spelling bee winner or typest but i tihnk most can undestand what i'm trying to say. if in fact english isn't his first language i do apoligize for being harsh and want to redirect my post to everyone else that can't spell of talk like they're 16 and in a chat room.
Old May 21, 2004 | 03:49 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Line locks can be used to hold in pressure(keep brakes locked) or hold out pressure(prevent brakes from applying). It can be placed in either the front or rear, so you can do what you were trying to explain.
Old May 21, 2004 | 06:57 PM
FOX-GTA_89's Avatar
sorry ...
I'll do my best now.
so to make it work like i want, can you explain me how to do it properly because in the instruction sheet they only explained how to do the old on brake setup not the opposite. Is it connected the same way exept that i switch in and out up side down. yes i want it to work as a proportionning valve 100%brake in front 0% in rear and when i flip back the switch the brakes work like they should stock. do you understand now...mi line lock by the way is the B&M launch control.
and guys before i chat on this site i never used english before.
Old May 23, 2004 | 04:15 PM
dankhound's Avatar
Car: 91 RS
The whole installation will be exactly the same it will just be in a rear brake line instead of the front.
Turn the swich to on and then do your burnout. When you hit the brake pedal only the front brakes will work.
Old May 23, 2004 | 05:35 PM
ede's Avatar
ede
FOX check your PMs
Old May 24, 2004 | 04:31 PM
FOX-GTA_89's Avatar
dankhound
thats exactly how i want it to work but you guys seems to dont undertand my kit explain how to install it to make work like this.
push brake, hold switch, leave brake pedal,keep olding switch,burnout(car 100%stopped)leave switch=brake release but i want it to work as a empty fluid rear brake just when i flip the switch....COMPLETELY DIFFERENT!!!
Old May 24, 2004 | 06:30 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
What you want to do is set up the line lock on the brake line heading to the rear brakes (just after it leaves the proportioning valve). To operate it, you hit the switch first. Then, push down your brake pedal. Fluid will go to only your front brakes so your rear brakes won't engage. Then do yourburnout and feel free to release the brake a bit to roll forward. After releasing your brake pedal, hit the switch again. When you're at the end of the run, pushing the brake pedal will allow all brakes to work to stop you.
Thinking about it, that isn't a bad way to set up a line lock at all if you have an automatic tranny.
Old May 24, 2004 | 08:30 PM
FOX-GTA_89's Avatar
exactly!!!!!but how!!!!
and im standard!!!
Old May 25, 2004 | 03:35 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
you may want to reconsider that setup if you're running a manual tranny. You will have to get into first gear and spin them, then very quickly move your foot over to the brake pedal to slow yourself down. It kinda takes away half the benefit of having the lock. I'm going to install one soon on my front brakes, but haven't done it yet so i'll leave it to someone else to explain the installation process.
Old May 25, 2004 | 04:35 PM
FOX-GTA_89's Avatar
true all the way....but
i want my car be able to move wile burnout!
Old May 25, 2004 | 08:00 PM
dankhound's Avatar
Car: 91 RS
heel toe
*** gave me two feet and three pedals(dont know what he was thinking). Gotta hittem all somehow.
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
