what is this called.
Old Jun 16, 2004 | 06:39 PM
treeohfive's Avatar
wtf is this called.
i should know this, so sad i dont.
A solenoid that locks your BRAKES. you press the brake pedal down, flip a switch, soenoid egauges maintaning brake fluid compression, in return holds the brakes so you dont have to.
Old Jun 16, 2004 | 06:42 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
line lock
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
a line lock or roll control
Old Jun 16, 2004 | 09:27 PM
treeohfive's Avatar
ah ....ty...any suggestions on a decent one? is the JEGS one for 45 any good?
this seems like something you could do yourself, meaning not have to buy a kit especially for it....seems like you could pick up a solenoid for like 15 bucks and do it.....
Old Jun 16, 2004 | 09:34 PM
nolanr0413's Avatar
Car: Trans am
i have the hurst line lock , its supposidly the best one you can get , and i guess you can also rebuild it .
Old Jun 23, 2004 | 02:04 PM
copperhead110's Avatar
Do you put line locks on your daily drivers?
The line lock is only for the front brakes right? Its purpose is to allow you to do a burn out without the back brakes dragging.
I've wondered about one, but feel uneasy (paranoid about a device that can lock up my front wheels.
Old Jun 23, 2004 | 02:08 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
slp makes one that comes with lines already bent and everything. i think its a $140
Old Jun 23, 2004 | 05:29 PM
treeohfive's Avatar
in order to use the line lock you must press and HOLD the brakes down THEN flip the switch....and itll lock the line...youd have to be doing a whoooole lot wrong to *accidently8 lock the line...and if you can install it, chances are you arent dumb enough to accidently lock the line while driving,.
92purpz28
Aug 11, 2015 02:30 PM
paul5.0
Aug 31, 2011 10:12 PM
hawaii
Jan 23, 2005 07:58 PM
cfirebird86
Jan 6, 2003 05:25 AM
