Strut top mount bolt
Old Jul 9, 2004 | 10:33 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I am trying to replace my struts and the top mount bolt and the stud both spin,any ideas?
Old Jul 9, 2004 | 11:24 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Look at the top of the threaded rod. Either an allen wrench, torx bit or small open/box wrench will fit on that along with the large wrench on the bolt itselft. Twist oppositely.
Old Jul 9, 2004 | 11:25 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Nope, there smooth.The ends are round.
Old Jul 10, 2004 | 07:39 AM
Spdfrk1990's Avatar
They all should come with a allen or have flat edges to get a wrench on.
Old Jul 10, 2004 | 11:34 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If anything get some vice grips and break the bolt loose. If you can't get a grip there, put the vice grips on the shiny portion of the strut under the boot in the fender. (that's IF you're not re-using the struts)
Old Jul 11, 2004 | 05:50 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Been there
I had the same problem when I went to install my AGX's. What I did to solve the problem was to use a strap wrench from Sears and put it around the strut. Then used my impact wrench on the bolt. Worked pretty good for me. Let me know if you need any more help on that.
Old Jul 12, 2004 | 02:25 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Thanks,I'll give that a try.
Old Jul 12, 2004 | 03:04 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
buy new strut mounts
my were creaking horrible, but it sure made removal of old ones easier.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Elliswon
Aug 10, 2015 12:33 PM
