Suspention work worth it with drag radials??
Old Jul 15, 2004 | 12:20 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I have been thinking about geting some drag struts and shocks and the relocation brackets and what not. But I was thinking that say I have a set of drag radials or slicks on the car and I want to leave the line at 3500rpm and I hook then is there any benifit to doing the suspention work? Is hooking hooking no matter how you do it? Or would the suspention work reduce my 60foot times even more?? Thanks for any input guys...
Old Jul 15, 2004 | 01:22 AM
25THRSS's Avatar
I'de do subframe connectors regardless, but if you hook, you hook. Why waste your money when you don't need to? The only thing I can think of is if you are getting air in the front and might benefit from some different shock/springs to help control the car when the wheels come down.
Old Jul 15, 2004 | 02:45 AM
Car: 89 Formula
Engine: Carbed 5.7
well I have subframs, lakewood lower control arms, and an edelbrock panhard rod, no front sway bar, and skinnies. I guess I will run with my radials and see what happens..
Old Jul 15, 2004 | 11:25 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
id say still do the lca relocation brackets. cheap and easy install, especially if you can weld
Old Jul 15, 2004 | 01:51 PM
Car: 89 Formula
Engine: Carbed 5.7
yea but if i am already hooking then its just 100 bucks wasted right?
Old Jul 15, 2004 | 02:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
not necessarily. what kinda 60' were you pulling? with better suspension, you could leave even harder
Old Jul 15, 2004 | 08:31 PM
25THRSS's Avatar
How? If he is already dead hooking, it's a waste.
Old Jul 17, 2004 | 04:04 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
Higher rpm
Old Jul 17, 2004 | 09:17 PM
25THRSS's Avatar
Originally posted by XJOSHX
Higher rpm
Higher rpm doesn't mean more power necessarily, but I know what you meant. That may be true if launching higher causes him not too hook, but the question was if he is already hooking will it help him. If anything it'll slow him down a bit from the added weight.
Old Jul 20, 2004 | 02:34 AM
Car: 89 Formula
Engine: Carbed 5.7
ok guys I am going to the track on thursday with the radials for the first time, Now if i hook good theres no point in doing drag struts and shocks, and getting relocation brakcets??
Old Jul 20, 2004 | 06:43 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Ask me about hooking on a stock factory suspension with 120,000 miles on everything going off a transbrake @ 4200rpm.
If your hooking your hooking period. I tried the relocation brackets and did'nt see any change in 60'. The suspension stuff wil help you tune the car but if your hooking your hooking.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Streetstuff
Sep 7, 2015 09:23 AM
