Battery Relocation
Old Jul 15, 2004 | 08:35 AM
Spdfrk1990's Avatar
Battery Relocation
Does any1 have pix of how they mounted theres. I did a search and seen a few even saw a bracket from bmr but ide like to put it in a battery case.
Old Jul 15, 2004 | 08:51 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
I put my sealed moroso battery box where the spare tire used to be... PICS of it would be hard to do...Basically Involed some creative cutting of the spare tire holder...light hammering of the area and then welding up a base for the box to mount to....
BUT my plastic covers all of it up and you would never know its there unless I told you..
Since your from cincinnati maybe Ill see you at a cruise in or at the strip to show you in person as Im from cincinnati as well...
Old Jul 15, 2004 | 11:50 AM
Spdfrk1990's Avatar
Yeh i think i saw you in the GCFBA site b4. I need my irocs polished or new rims b4 i cruise again. I took the irocs off to polish them and havnt finished if you know how wanna help lol. Im doin brakes right now and when im done ide like to have some new wheels. Im too embarressed to drive around on ****ty 15's that i have.
Old Jul 15, 2004 | 12:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I put my optima in the rear passenger side seat well, to lower th polar moment of inertia. I made a 3" aluminum strap that bolts to the seat belt holes.
Old Jul 15, 2004 | 03:07 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Yeah but even with an optima battery you wont pass through tech like that...
I know how to polish rims... But Im not volunteering on that pitfa job....LOL
Old Jul 15, 2004 | 03:18 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Maybe not strip tech, but dragging is really that fun or my cup of tea. SCCA rules state that: Relocation of the battery or batteries is permitted but not into the passenger compartment. If the battery is relocated and the original battery tray can be removed by simply unbolting it, the tray may be removed, or relocated with the battery. Holes may be drilled for mounting or passage of cables. Longer cables may be substituted to permit relocation. The number of battery or batteries may not be changed from stock. The area behind the rearmost seat is not considered to be within the passenger compartment.
But if you only have front seats, the battery is behind the passenger seats.
Old Jul 15, 2004 | 07:22 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
there is a picture on the cars website
Old Jul 16, 2004 | 09:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I recently put mine to the rear. I like this way, cheap too!!! Legal too because its vented properly...
Old Jul 16, 2004 | 09:24 PM
Spdfrk1990's Avatar
Nice but the plastic wont cover it up there will it.
Old Jul 16, 2004 | 10:54 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
If you have the locking security cover it will.
Old Jul 18, 2004 | 02:50 AM
Kandied91z's Avatar
throw it in either side...preferably the spare tire side and use a drycell. you'll be fine at tech inspections no matter what anyone says. if your running so fast it's a problem or racing that much for money you wouldn't be asking.
definately go drycell though, no need for large ugly boxes and it's alot safer. more power output as well.
Old Jul 18, 2004 | 03:42 AM
Spdfrk1990's Avatar
Thanx kandied
Old Jul 18, 2004 | 02:47 PM
Kandied91z's Avatar
whatever you do make sure your power wire is tucked up and hidden well on either the underside or inside of car. many have left it inside the car, i ran mine on the outer edge underneath. you can pick up most of the relocation parts dirt cheap through many different places. i welded a tray where the tire used to be but it isn't necessary. just a piece of mind for myself so it wouldn't move.
i've been running an interstate red top battery for almost 4 years now and it's been very nice. no holes to drill for vent tubes and you can reuse all your interior pieces if needbe since you don't have to have a big battery box.
good luck with it.
Old Jul 18, 2004 | 02:59 PM
Spdfrk1990's Avatar
Yeh this kit from bmr looks nice http://www.bmrfabrication.com/misc/bb-install2.jpg
Old Jul 18, 2004 | 03:00 PM
Spdfrk1990's Avatar
This kit from bmr looks nice
Old Jul 19, 2004 | 01:04 AM
Kandied91z's Avatar
basically how mine is...i just used a cheap $5 tray though with mounting points for a bar tie down on the battery. tacked it in place with a few choice welds to keep from drilling holes and was done.
basically same thing, looks much nicer that way.
Old Jul 19, 2004 | 06:13 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
like 92 zzz28 it's an enclosed model, 'sept mine isn't vented with the sealed Optima. The re-lo kit does include the hardware though. I installed a bulkhead fastener to get the wire thru the firewall, don't just drill a hole and stick the cable thru.
Old Jul 19, 2004 | 12:59 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
PF where is that battery located? It looks kinda like the rear seat well.
Old Jul 19, 2004 | 01:46 PM
Spdfrk1990's Avatar
Looks like the trunk to me.
Old Jul 19, 2004 | 04:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it looks like it's in the rear well at the back of the car. similar to where i mounted my battery. have a pic of that switch from the back of the car?
Old Jul 19, 2004 | 04:50 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Actually it kinda does now that i look at it closer. But that must be a huge battery or some optical illusion because it looks like its taking up the whole well.
Old Jul 19, 2004 | 05:39 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
... it's in the rear trunk area.
As far as the switch, you can kind see it next to the right tail light
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
