Pics of my front LS1 brake swap, PST kit, etc,etc...
Old Jul 16, 2004 | 04:26 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well after 180k miles on my car, I figured it was time to rebuild the frontend. Here is what I'm doing, this is my latest mini-project until I get my 12bolt/9" and my LS1/6speed swap completed.
Here is a pic and here is what I'm doing:
-all new bushings, ball joints, tie rods, endlinks, etc... PST polygraphite kit
-new KYB struts (new KYB shocks on the rear as well)
-Eibach Sportline springs (front and rear)
-putting my 36mm swaybar back on w/ all poly mounting pieces
-sandblasted and powdercoated a-arms and spindles
-stock spindles modified by me to accept the big LS1 brakes
-custom caliper brackets from Ed Miller to run LS1 calipers on my spindles
-polished\painted LS1 calipers
-"Russel" stainless steel/braided brake lines (front and rear)
-custom hubs (stock 3rd gen rotors machined down) w/ longer wheel studs
-all new bearings, seals, and races in the hubs
-stock LS1 rotors and pads (front and rear)
*I think that is about it.... and oh yeah, my 17" wheels and tires (4th gen WS6 rims w/ firehawk rubber) should be here sometime next week Looks like I'll be doing some corner carving before I put my LS1 in and hit the dragstrip.
All these mods are in addition to my other suspension mods I already had....
-Lakewood LCA's
-Lakewood APHR
-SSM SFC's
-poly rear sway bar mounts and endlinks
I'm really curious how this thing is gonna handle when its done. What do you guys think? I'll take pics as I do the swap and post final pics of the car with its new stance and new wheels/tires. Later
Old Jul 16, 2004 | 08:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nice!! You'll like the Eibach/KYB combo. I know they're not the best strut/shock out there but they're good for the money.
Ed
Old Jul 16, 2004 | 09:08 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
nice kit man when you getting it on the car?
Old Jul 17, 2004 | 12:33 AM
Spdfrk1990's Avatar
I have the kybs with the hotchkis wish i had got bilsteins.
Old Jul 17, 2004 | 07:37 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Are you replacing the upper strut mount?
With that much milage they NEED to be replaced!
The ones that look like this:
Attached Thumbnails Pics of my front LS1 brake swap, PST kit, etc,etc...-upper-strut-mount.jpg
Old Jul 17, 2004 | 07:56 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Looks great!!!
Your going to need LCA relcation brackets soon.
Old Jul 17, 2004 | 09:42 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Where can I get those upper strut mounts at a decent price? They don't look to hard to replace. Please let me know, some others have suggested those and I'm trying to look into that more.
I will need some LCA reloc's along with some shorter swaybar endlinks too.
I can't wait to get it all on, I hope it turns out well!!
-Jeremy
Old Jul 17, 2004 | 01:07 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i got mine from rockauto for like $46 each i think
Old Jul 17, 2004 | 07:52 PM
camaro of solar's Avatar
what all needs to be done to swap out hte strut mounts? I know mine are in a bad way...
Old Jul 17, 2004 | 08:13 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
jack the car up, put jack stands under on the frame. then take the jack, and jack on the control arm, until the suspension is compressed. use a felt tip marker to mark along the outside of the old mount. remove big bolt in the middle, and then the 3 on the outside. remove old, replace with new, put all hardware back. lower jack, repeat on other side, then drive to alignment shop
Old Jul 17, 2004 | 08:16 PM
excellent i was worried that something might have usues wiht the mount being removed......sounds like this si somehting to do when i do springs struts tierods a-arms etc....
Old Jul 29, 2004 | 12:23 PM
cdh67's Avatar
Car: 84 Z..err 92 now
Engine: 402 LS1 Procharged-14 psi-629 hp!
GTA91- Let me know if your drag lites fit when you get the LS1 brakes on.
Old Apr 23, 2005 | 03:16 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Old post I know, but where can I get those upper strut mounts/bearings???
Thanks!
Old Apr 25, 2005 | 03:41 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Spohn.net has them online.
Old Apr 25, 2005 | 08:42 AM
Joehrdcor's Avatar
Car: 89 Firebird Formula
Engine: 305 TBI
Kaga15, correct me if I'm wrong but doesnt the shock need to be fully expanded to do any removal. Jacking up the control arm to compress the suspension could result in the shock jumping up?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
