Sportlines and GR2's finnaly on
Old Jul 24, 2004 | 05:45 PM
The Red86Z's Avatar
Car: 86 Z28/91 dodge stealth rt TT
finnaly got them on, Before they went on the car sat uneven on all 4 corners passenger side was almost a full inch lower than the driver side. Now it still is uneven but just BARELY and not even noticable.... What causes this?? Well anyway heres a few pics.
Old Jul 24, 2004 | 06:29 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
wow, thats pretty low, and looks good, glad i went with the pro kit, you prolly bottom out on everything.
btw, you read chitown or mfba?
Old Jul 24, 2004 | 10:50 PM
3gc's Avatar
3gc
Car: Z28
Looks good. I don't think you'll have a problem with bottoming out. I have intrax springs which is a 2" drop and don't bottom out often. When i had 15" rims with smaller tires i did a lot but once i got the 16" rims and correct size tires it's prefectly fine.
As far as one side sitting higher then the others. Has the car ever been in an accident? Did you check to make sure tire pressure was even? There are other reasons probably but those too are possible causes that come to me now.
Old Jul 25, 2004 | 01:01 AM
The Red86Z's Avatar
Well, before i got the car i guess it had "Minor front end damage from collision with dear" but other than that none that i know of. Could it have just of been the old springs sagging more on one side for some reason?
Old Jul 25, 2004 | 11:45 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
looks great. the springs still have to settle, so it may not end up being unlevel at all.
Old Jul 25, 2004 | 12:27 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Deer are big... *could* have frame damage.
Anyways, I just paid for some GR-2s and Gas-A-Justs for my car. I'm leaving the stock WS6 springs for now. Since I just blew my differential last night (right after I paid for the shocks/struts incidentally), I'm going to swap in a 4th gen rear and I'll do the rear shocks then, and I'll do the GR-2s when I do my front brakes with my slotted/drilled rotors (probably the same time actually). But I don't have enough cash for new springs, and I really don't want to lower my car any at all anyways. As it is, my 3" cat-back hangs a bit low and only gives me a few inches of clearance.
I can't wait to feel the ride difference between the 80k mile original stockers and the new GR-2/Gas-A-Justs though!! How do you like the ride so far?
Old Jul 25, 2004 | 05:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Double check to make sure you indexed the front springs correctly. I bet that is your problem. My sportlines did not settle. They sat perfect from day one and have not changed 4 years later.
Old Jul 25, 2004 | 05:49 PM
The Red86Z's Avatar
Yes, the front springs are indexed correctly. the side that was almost a full inch lower before, is still the side thats lower but like i said barely at all, and the passenger side rear is also slightly lower the the driver rear. DuronClocker so far i'm very happy with the ride, kind of wishing i would have got the Gas-A-Justs though, oh well. And no i haven't had any problems yet with bottoming out
Old Jul 25, 2004 | 06:29 PM
Spdfrk1990's Avatar
Dang i cant wait to buy some sport lines so how doesnt it ride. Is it real rough?
Old Jul 25, 2004 | 06:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is rough but bareable. Rememeber, you are driving a sports car.
Old Jul 25, 2004 | 06:51 PM
Spdfrk1990's Avatar
It prob depends alot on what shocks you have ide say. My hotchkis and KYB combo isnt too bearable.
Old Jul 25, 2004 | 07:42 PM
The Red86Z's Avatar
yes it is rough, but anything is better than the 100k mile stock ones were.
Old Jul 25, 2004 | 07:58 PM
Spdfrk1990's Avatar
All this rough ride stuff is almost makin me want to get the pro kit.
Old Jul 25, 2004 | 09:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Other than ride height there won't be much difference.
Old Jul 25, 2004 | 09:24 PM
Spdfrk1990's Avatar
Hows that the sport lines would have to be stiffer.
Old Jul 25, 2004 | 09:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
There isn't much difference. Performance suspension and comfort never go hand in hand. If it is comfotable than you can get more out of it.
Old Jul 25, 2004 | 09:52 PM
Spdfrk1990's Avatar
Really i dont mind the bumps i just dont like the sounds my car makes when it hits them. Maybe a roll cage or somethin will cure that. I have sfc's but they didnt help much.
deracer
Apr 11, 2016 12:04 AM
loud91rs
Oct 5, 2015 10:05 PM
Chiknhawk
Sep 10, 2015 08:55 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
AustinT
Apr 15, 2001 09:43 PM
