E-brake ????
Old Jul 29, 2004 | 02:14 AM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
E-brake ????
Well i was trying to put on my e-brake cable today and couldnt, becouse there wasnt a ajusting screw. My buddys camaro has it why not me? Can it be in a different place (the adjusting screw)??????
Old Jul 29, 2004 | 06:50 AM
Spdfrk1990's Avatar
We have the same car and mine doesnt have it either. I think they stoped it in 89 or somethin.
Old Jul 29, 2004 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Do a search (I'm sure that the problem has been discussed). If I recall correctly, 90 up is self-adjusting.
JamesC
Old Jul 29, 2004 | 09:56 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
i trid doing a search and nothing came up. The thing is that i converted to a 9 bolt posi disc with 3.45, from a open 3.08 drum. So what i did is that i used the e-brake cables from the drum, becouse the disc e-brake cable were all messed up. What should i do?
Can you some how buy the ebrake cable adjuster froma leter year and adapt it some how?
Old Jul 29, 2004 | 10:47 AM
Spdfrk1990's Avatar
Do you have the pbr's? I have the older pre 88 style and they didnt work now with the pbrs im hopin it will work ok.
Old Jul 29, 2004 | 11:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What you should do, is buy the correct parking brake cables that go from the adjuster (or the "not adjuster" as the case may be) to the calipers, and just hook them up.
Do a search; this question comes up every couple of days, and the part numbers that you could get at several of the chain parts stores that will work (seems like I remember seeing at least NAPA, Advance, and Auto Zone #s), their lengths, the discontinued GM part #s that they replace, etc. etc. etc., have all been posted recently.
Old Jul 29, 2004 | 11:20 AM
JamesC's Avatar
Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Jul 29, 2004 | 11:59 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
i dont have pbrs and that post didnt tell me anything about the e-brakes. You think that auto zone, or discount even has them???
Old Jul 29, 2004 | 12:27 PM
JamesC's Avatar
Sorry, I assumed the 9-bolt had PBR's (The link did provide an e-brake part number and its length if you read carefully). Your best bet, as RB mentioned, is to call around to Napa, CarQuest, etc.
JamesC
Old Jul 29, 2004 | 03:48 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
With his car being a '90, no. That year has no adjustment on the lever cable in the trans tunnel.
Sure you can but I don't think this is the final answer to your problem..by your posts, you went from a drum rear to the iron caliper 9 bolt 3.45. You need brake cables for that rear, obviously, and no the drum cables won't work. Napa online gave me these part numbers:
NAPA United Parking Brake Cable - Lt Rear UBP 93084 $27.49
NAPA United Parking Brake Cable - Rt Rear UBP 93215 $21.49
www.napaonline.com I used an '88 Camaro for the search car. So, you can buy these cables and install an older parking lever assembly which gives you adjustment and you'll be fine, but I'd also take a look into those calipers...they're probably frozen up and in need of the recall kit.
Ed
Old Jul 29, 2004 | 07:18 PM
Spdfrk1990's Avatar
Even if he buys the right ones tho like i did i still dont think they will work right they didnt on my car. It cause he is putting pre 89 brakes on a 90. They wernt meant for the non adjusters.
Old Jul 29, 2004 | 07:25 PM
ebmiller88's Avatar
Right...I'd swap the e-brake lever out for an older model to make them work.
Ed
Old Jul 29, 2004 | 08:12 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I did what EB just suggested and got a ebrake lever out from a 89 and installed it on my 91. Well...when I had a 91 that is. Might also wanna check the condition of the cables. I found that the passenger side plastic coating on the cable had come off and got itself stuck inside the outer cable. So one side wouldn't even engage. O_o
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
