Help with stance of the trans am
My 85 ta sits way too high and i have sportline springs on it. I took the isolators out and have heater hose taped to them so that thier isnt a metal to metal contact. I just put some new bilsteins on and cut off half a coil and the car still sits too damn high. I think it has something to do with the chrysler rear end and the axle tubes being bigger so that it raised up the car . Im wondering if i should cut another half coil off and if i do will it cause any trouble.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I'm betting a larger rim with some lower profile tires will give you the look you are going for. Either that or you could go for some GTA rims. The place linked below apparently has a good deal on some GTA rims:
Classic Industries Catalog DL
But really... the car looks great to me.
looks like another half coil is coming off soon. Also can i change the spring without taking off the rear rims, ive always taken em off b4 and i wonder if i can do it without taking them off. also slp iroc z hows the ride , i have new bilsteins in the rear , and i still wanna lower it more, i think it needs it . How did u get yours so low, and dont you scrape everything with the front now .
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Changing the rear springs and shocks was easy for me, I just jacked it up my the axle, put some jackstands under the CHASSIS, then slowly lowered the axle making sure not to destroy the brake line. From there I managed to pop out the old springs by hand and put in my prokit. You might have to loosen the brake line from the chassis, but I didn't have to at all. Did the shocks at the same time and didn't have any issues nor did I see any reason to take off the wheels.
well now i just want an answer as to why my car sits so high with a half coil cut and no insulator. The only thing i can think of is that the rear end spring perhes are up higher on the axle and this is why it sits high. I think im gonna take another half a coil off.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
personally i think that stance is perfect, a little rake is good.
my sportlines are stock, i didnt cut them. however i did not use isolators in the rear when i installed them.
oh yeah, i think my car rides really good with these springs in it, the stock springs never gave as nice of a ride. better handling and better ride, and great stance, i love em.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You only have like and inch and a half ground clearance with your air dam as it is.. why go lower? It looks great. Nice rims by the way, what size are they? I'm going to be putting some C5 17" fronts and 18" rears on my car come spring (buying rims in a few days). Too bad the 35 and 40 profile tires are going to cost me $700+
Car: 1999 Z28
the size of the rims are in the sig. slp iroc do your springs squeak without the isolators.
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
