How tall of tires to get for skinnies?
Old Sep 13, 2004 | 03:45 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I've got my weld 15x3.5 skinnies on the way, and am working on deciding what sized tires to get. I know I need 165 r 15's but what hight? 165/XX/r15
What should I go with in the XX? 75?
Old Sep 13, 2004 | 07:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you have no choice. the tire size is 165R15. there is no sidewall size.
Old Sep 13, 2004 | 09:04 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I was told at the place i'm getting the tires i can get anything from 55's to 85's
anyone know?
Old Sep 13, 2004 | 10:08 PM
xpndbl3's Avatar
Car: 1984 Z28
these are metric tires. they don't have a sidewall number on them. although i'd assume it's 165/75R15. but who knows. they're 25.3 inches tall if that helps. basically they are factory VW bug type tires.
Old Sep 13, 2004 | 10:25 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
alright, maybe i was just talkin to an ignorant employee, its happened before
Thats a good idea, i'll just look at the overall height for figuring out what i need.
Old Sep 13, 2004 | 10:30 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i like the 205/75/15 myself. depends on your rear tires.
id go with the 165/15's if you run 26" rear tires
205/75/15 if you run 28" rear tires.
Old Sep 14, 2004 | 06:45 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just be careful with that small of a front tire, when we put them on the truck we lost all R/T adjustibility since they are soo fricken small and lights were red red red. These small of front tire see little to no difference at all with pressure changes for tree tuning.
Old Sep 14, 2004 | 02:37 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
^^ several bracket racers down here run the 27" front runners or the 205/75/15 radials for that same reason.
the rollout on the lil tires is horrible.
InfernalVortex
Apr 20, 2021 11:31 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
