Rear Coil overs
Old Dec 2, 2004 | 08:08 AM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
Transmission: five speed
Rear Coil overs
Is anyone here running rear coilovers? Post pics please?
I want to see how they work. do they just replace the rear shocks, or do they require custom brackets?
:lala:
Old Dec 2, 2004 | 09:13 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
It requires custom brackets to distribute the coilover load back to the spring can next to the shock mount. There have been many cases of that chassis mount area completely corroding and busting through just from the pressure of the rear shock- never the less a coilover holding the weight of the car.
Old Dec 2, 2004 | 12:47 PM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
I am aware of this, I punched an air shock right through the shock mount on an 82 I had. I was thinking of using a rear shock tower brace tied into the rear legs of the roll bar, but I'll check out these brackets. Do you have a link to a set of them?
Old Dec 2, 2004 | 08:49 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
They are designed & prototyped but not quite ready for production yet- very soon though
Old Jul 28, 2007 | 06:40 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
Re: Rear Coil overs
HAL-DR2000K
this universal coil over kit from qa1 looks like it could work in the 3 gen f bodies
Old Jul 28, 2007 | 08:52 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Rear Coil overs
http://www.spohn.net/product.cfm?productid=1533
That is Spohn's kit to make a direct retrofit. Looks like a straight forward deal. I will be making the upgrade soon(front and rear).
Old Jul 28, 2007 | 10:59 PM
Car: 86 Camaro
Re: Rear Coil overs
that looks like a good deal a little more engineered for the third gen. body than the QA1 kit i may look into that one a little more. i want to put a 8.5 10 bolt rear end in mine maybe do it all at the same time.
Old Jul 30, 2007 | 03:36 PM
Shagwell's Avatar
Car: projects.......
Re: Rear Coil overs
If you've got a cage and are planning a rear swap, why not run the custom type set-up? Unless you hack job it in there it's gonna look and work better than just band-aiding onto factory swiss cheese.
Old Aug 4, 2007 | 11:32 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Rear Coil overs
I made my own set. Just bought a set of qa1 coilovers that were the same length as my shocks. Cut a 1/4 inch piece of steel for the reinforcement of the upper shock mounts. Basically I copied Spohns parts. You can piece it together cheaper. The adjustability is great.
Old Aug 8, 2007 | 06:38 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Re: Rear Coil overs
Can you remember what the length was at all?
Old Aug 8, 2007 | 03:46 PM
Shagwell's Avatar
Re: Rear Coil overs
nice pic - needs more rear anti-roll bar....
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
TheExaminer
Aug 25, 2015 07:34 PM
