how to make rear wheels stick out . . .
Old Feb 8, 2005 | 11:27 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
whats up guys, what do you call them, spacers??? I just want the rear wheels to pop out a bit, give it a more agressive look-and where can I find them, and for how much?
thanks in advance
Old Feb 9, 2005 | 01:12 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Just go buy a 4th gen rearend. It'll be just a bit more than the spacers and you'll get better rear brakes along with quite possibly a better gear ratio and posi (if you don't already have it). That'll kick the tires out 1 5/8" on each side. That was my setup for a while til I went with 4th gen rims.
Otherwise, yes buy spacers.
Aero spoiler for sale...how much you want and where are you located? Shoot me a PM.
Old Feb 9, 2005 | 07:04 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
You will still have to buy spacers in order to use 3rd gen wheels on a 4th gen rearend
Old Feb 9, 2005 | 08:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, you don't need spacers to run 3rd gen wheels on a 4th gen rear. Unless of course, you know of somewhere that you can buy spacers, that make things thinner instead of thicker. I for one have never seen such a spacer.
You do however need spacers to run 4th gen wheels on a 3rd gen rear.
People put 3rd gen wheels on 4th gen rears all the time, to get that stupid silly r¡cer skateboard wheel effect. I laugh at it every time I see it. It looks ridiculous. Like a Suzuki Samurai with deep-dish chrome wheels on it. I would pay money to repair that defect, if I bought a car and it was equipped like that.
Old Feb 9, 2005 | 12:15 PM
91Z28-350's Avatar
Going for whitewall low profile tires on 14" rims with gold spokes sticking out 3 inches?
Depending on how much you want to push out, you'll either need spacers or adapters.
http://www.skulte.com
Old Feb 9, 2005 | 12:31 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
other way around.
3rdgen rims on a 4thgen rear stick out.
they're not out beyond the fenderwell, but pretty close to the edge.
if it had more tire that went all the way inward, it wouldnt look bad.... from a front 3/4 view, the fenderwell looks full of tire........ except that from the rear it looks silly because its still only a 8" wide rim.
Old Feb 9, 2005 | 05:24 PM
White91GTA's Avatar
Engine: 5.7L TPI
Doh...wasn't thinking straight, I had it backwards
Old Feb 9, 2005 | 05:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's OK, we all do that once in a while.
Old Feb 9, 2005 | 07:14 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by MrDude_1
other way around.
It depends on the wheel style.
Stock 16" with the rear offset sit pretty good, but 0 offset wheels like the fronts will stick out past the fender well.
Here are 2 examples,
LS1 rear with rear offset 16" GTA wheel,
LT1 rear with 0 offset (same front and rear wheel offset)
Old Feb 10, 2005 | 10:14 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
http://www.transamws6.com/pics/formula/ls1_3.jpg
http://www.transamws6.com/pics/4th_gen_rear.jpg
good point.
didnt think about that... i just run my fronts on the front and rears on the rear.. i never thought about swapping them...
Old Feb 10, 2005 | 06:00 PM
Zepher's Avatar
good point.
Well, you can't really swap the rears to the front, most cars will have issues with the inner lip of the rim rubbing on the tie rod ends.
I've always ran 4 front offset wheels, except for the last set of GTA's I had.
Here is what front GTA's look like all around,
and what it looks like stock,
Old Apr 20, 2005 | 08:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think it looks better with the tires out abit farther. it aint all that much farther. looks ok.
how much will that improve handling? by moving the rear track wider? i figured it would be a good improvement and cut out oversteer if the rest of the suspension is set up right
Old Apr 20, 2005 | 08:32 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
just put some 325/50/15s on it on a 10 in rim 5.5 bs lol only prob is i want mine to stay in the wheelwell
Old Apr 21, 2005 | 12:41 AM
Spdfrk1990's Avatar
Its easy if you were born in kentucky.
Old Apr 21, 2005 | 11:43 AM
Car: 1997 Corvette
I had noticed a difference in handling. Seemed to stick better around turns, and that was with stock suspension. I no longer use 3rd gen wheels though so I can't make any comparisons now that I have everything else done.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
