should i cut these dropzones first
Old Mar 18, 2005 | 09:06 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Hey I just got these dropzone springs and i'm putting them in tommorrow, i dont want any wheel to fender gap, I did a search and saw that yous have experimented with these springs, soon i will be installing these 18" z06's but dont want any wheel gap. Should i touch these springs as in cut alittle bit off before i put them in and be pissed with results lol? if so how much just let me in on all the info. THank you
Old Mar 18, 2005 | 09:22 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
if you dont want any gaps you will probably have to take a 1/4 coil off and trim your bumpstop down a bit... if you want more then another 1/4 coil
heres what the fully compressed gap is with a 17" vette rim with the ridge of the bumpstop cut off.. the tires a 245/40/17 that are about 1/2" shorter then a stock 245/50/16.. so you can compare that size to your 18
Old Mar 18, 2005 | 09:27 PM
Car: 2002 SS
Engine: Ls1
as in 1/4 do you mean just measure from the end of the coil, as marked in the picture over a 1/4 of inch and cut there?
Old Mar 18, 2005 | 09:29 PM
Car: 2002 SS
Engine: Ls1
wups here
Attached Thumbnails should i cut these dropzones first-c-documents-settings-sean
Old Mar 18, 2005 | 09:53 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
yeah a 1/4" from the end of the spring.. that takes it down about another 1/4" to 1/2"
those are nice springs.. where do you get them from.. they dont look anything like my jamex springs
Old Mar 18, 2005 | 09:57 PM
Car: 2002 SS
Engine: Ls1
I bought them off of (fastrnu) on here. He was nice enough to sell me them since he got a new set up. So should i cut 1/4" on both the fronts and rear. 1/4 of an inch can make that much of a difference?
Old Mar 18, 2005 | 10:01 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
whoops.. no.. a 1/4 of a coil.. so 90 degrees of a coil.. i chopped off 1/2 a coil and if its too much i will have to get a set of these
Old Mar 18, 2005 | 10:03 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
the rears are easy enough to take out so if you dont like the stance its a quick change
Old Mar 18, 2005 | 10:05 PM
Car: 2002 SS
Engine: Ls1
lol i'm scared to do it, but i'll give it a shot
lol well if its done you cant take it back
Old Mar 18, 2005 | 11:05 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
i just did this install here is the link to the pics
link
Old Mar 18, 2005 | 11:12 PM
sellmanb's Avatar
Car: '86 Berlinetta
You'll have to cut them out, not torch them out btw.
I wouldnt do it until you get your new wheels ready to mount so you only have to do it once, and do it right the first time.
Old Mar 19, 2005 | 09:39 AM
Car: 2002 SS
Engine: Ls1
yeah i waited i dont want to mess anything up plus i dont want to be too low specially when i have some power in that car. thanks for the info and what you thought on everything
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
