Is the pitman arm keyed or splined
Old May 12, 2005 | 10:32 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
I wasnt paying attention when i put my 4th gen column in and now its 90 degrees out compared to the 3rd gen..
i just wanna know if i can pull off the pitman.. center the wheels and beat the damn thing back on there before i get it aligned
or is there anywhere like the rag joint you can do the same thing
Old May 12, 2005 | 10:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's master splined. You can only turn it 90* at a time but if it was never off then you'll only screw up the steering if you change it.
Why don't you pull the steering wheel off and center it?
Old May 12, 2005 | 11:11 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
i tried that.. the airbag, radio controls and horn are all keyed into the wheel so it looks like theres no getting around that..
i was lookig under there and can i just adjust the tie rods on each side shortening one and makin the other a bit longer?
Old May 12, 2005 | 11:44 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
No. You can't do that. That will seriously screw up your steering angles.
You should be able to rotate the steering column itself in the engine bay. There's a joint you can separate somewhere between the firewall and the rag joint. I don't know if you can adjust it by 90* though, I think only 180*..
Old May 13, 2005 | 12:05 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The input shaft of the box is splined, and can be adjusted there, near the rag joint. Remove the bolt there (underneath the plastic cover), loosen the column up (3 bolts to the firewall, and the two nuts under the dash) inside the car to slide it back, and have a friend help you.
Old May 13, 2005 | 12:24 AM
AlkyIROC's Avatar
Car: 87 IROC L98
The input shaft on the steering box is also master splined and will only go on one way.
Old May 13, 2005 | 08:54 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
i thought i replyed here.. maybe im just losin it
it is indeed keyed.. althought once you can spread the joint enough to get it 90 degrees and then beat it on again
my steering is now 98%.. just need an alignment for the degree or so that its out
so 4th gen columns do indeed work for third gens! eventually
Old May 14, 2005 | 01:06 AM
83 Crossfire TA's Avatar
for the most part, they're the same column, just dressed up differently
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
Gunsbee
Sep 7, 2015 07:10 PM
rudolphschenker
Sep 4, 2015 02:41 AM
