Alignment recomendations?
Old Jun 20, 2005 | 11:18 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Car is going back to the alignment shop(i know the guy, gives me a good dea, free) and last time it was in there he had an appointment and the camber was left a bit too strong, so its gonna go back to get that corrected, what im wondering is what would you guys recomend for specs to get a good handling, yet easy to control car that goes straight?
Here is what the specs are at right now.
Left front:
Camber -0.1
Caster 5.5
Toe 0.00
Right Front
Camber +0.6
Caster 5.5
Toe -0.02
Total Front
Cross Camber -0.5
Cross Caster +0.1
Total toe -0.02
Set Back +0.69
Left Rear
Camber -0.3
Toe -0.09
Right Rear
Camber -0.5
Toe -0.02
Total Rear
Toe -0.12
Thrust Angle -0.07
So what do you alignment guru's recomend? These settings were without someone in the drivers seat.
Old Jun 20, 2005 | 01:13 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Heres the specs im going with. Im not a guru but i have been told this are pretty good for a hard use street car.
caster
L= +5
R= +5.5
Camber
L= -0.75
R= -0.75
Toe
Total = 3/32
Old Jun 20, 2005 | 08:37 PM
92MaroRS's Avatar
anyone else?
Old Jun 20, 2005 | 10:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I got my alignment done I was more conserned about getting the toe set back up properly.
My rear end is only out about .5* but the front toe compensates for it so the car goes straight.
I tried to get zero camber but my front end is too reactive. I can pull the front end up and it will stay there because of the drag struts. We got it as close to zero as possible.
I wanted as much caster as possible since I'm only interested in straight line performance. I wanted 10* if I could but could only get 4.5* on both sides.
The car goes straight down the track once I get my launch straightened out.
From your numbers, I get that right camber closer to zero but it's already within the tolerance specs.
Old Jun 20, 2005 | 11:22 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Seems like you need more negative camber to me. Caster looks good though.
I'd shoot for -1* on both sides, but that might just a tad hard on the inside edges of the tires. -.75* like blyth mentioned would probably be a little better for a daily driver.
Old Jun 21, 2005 | 08:37 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
as a rule the car will pull to the side with the most camber and the least caster.
Old Jun 24, 2005 | 10:44 PM
92MaroRS's Avatar
Anyone else?
Old Jun 25, 2005 | 12:06 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
speaking of alignment....is it ok if i go with the following settings for a stock suspension on my camaro?...I'm looking for a little better stability for higher speeds so i thought 5+ caster might help...any suggestions?
Camber - 1/2
Caster + 5
Toe 0
Old Jun 26, 2005 | 02:05 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
In my above recommendation +5 degrees caster is what i recommended..I believe the .5 on the one side is suggested to the crown in the roads.
Old Jul 3, 2005 | 07:39 AM
Car: 1988 SC Camaro
Engine: 305 TBI
any other suggestions?...is +5 caster too much for a near stock car?....any potential problems?...would i be safer going with +4 caster?...I'm looking for a good strait line performance setting...something that will make my car nice and steady at higher speeds...
Old Jul 3, 2005 | 07:54 AM
92MaroRS's Avatar
Any reason why i could only go to -.20 on my camber on my drivers side?
Old Jul 3, 2005 | 09:51 AM
dharrison's Avatar
Engine: 355, 355
i use a hunter alignment machine at the shop i work at i looked up the stock spec's on the camaro and no year model 82-92 had a negative camber seting from the factory with 86 and eairlier having +1 degree and 87 later having +.3. caster was about 3.0 degree on 86 and eairlier model while 87 and up were 4.7-4.8 degree. what is the diffeance between the 86 and eairlier suspension and the 87 and later suspension? i recently purchased a 85 z/28 and i will align it soon i was wanting to know why everyone is suggesting negative camber and why the stock camber/caster settings are different for 86 eairlier models?
Old Jul 6, 2005 | 02:49 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
negative camber is better for stability in high speed turns.
Personally, I think positive camber is stupid on a 3rdgen, i believe it's more making turning easier, but I'm not too sure on that.
I haven't gotten the chance to really mess around with my camaro, it's just sitting, but I've got access to an alignment rack and have gotten every little setting in my honda just the way I want it on the toe.
Nice part is my job is looking at putting me as a service writer=$$$$ so I'll be really able to enjoy being 20 years old and living with my parents.
Old Jul 6, 2005 | 09:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I run as much negative camber and positive caster as allowed by the stock strut mounts.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
