You have Pro-Kits? What length endlinks do you have?
Old Jul 10, 2005 | 05:14 PM
CaysE's Avatar
I'm looking for the general concensus on what length endlinks those of you are using with a Pro-Kit drop. Normally I would just put everything together and buy the endlinks after measuring, but this is going on a daily driver with limited build time, and I'd like to have everything together ready to go. Post those numbers! Thanks!
Old Jul 10, 2005 | 07:07 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Re: You have Pro-Kits? What length endlinks do you have?
What ever the stock poly replacements i bought at NAPA are.
Old Jul 11, 2005 | 04:55 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
I just bought the Prothane Poly one's that spohn sells, but now I've been reading lately that you shold have shorter endlinks when you lower it?
Old Jul 11, 2005 | 05:40 PM
CaysE's Avatar
They should be slightly shorter. I'm just going to have to do some measurements to get a true number since it seems like everyone just goes with stock lengths.
Old Jul 12, 2005 | 06:45 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
please share afterwards...
Old Jul 13, 2005 | 08:07 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
What is it that you are going to measure? What is the goal in changing the endlink length? what is the effect of changing or not changing the length? I am installing weight jackers this weekend and will soon be changing the ride height. I was going to buy adjustable end links from ground coontrol but this would help me to know how I want them adjusted. If it matters my driving interest is auto cross.
Old Jul 13, 2005 | 09:10 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Basically you just want to have the endlink holes at the ends of the swaybars level with the car sitting at ride height. When you lower the car, the arms tend to angle upward on the front swaybar, and downward on the rear. You compensate for this by shortening the endlinks on both bars.
Keeping the ends level assures plenty of travel in both directions, and keeps the endlinks from angling too far and getting into a bind. It may not even be necessary, but that's the theory behind it.
Dean could tell you if it's worth worrying about or not.....I don't really know.
Old Jul 13, 2005 | 11:06 PM
83 Crossfire TA's Avatar
The control arm and the “arm” on the sway bar should be parallel to each other, and the endlink should be perpendicular to both. When you lower the car the enlink length to do that will change.
It will work if you use stock lengths, it just won’t be optimum… OTOH, if you get them too short you run the risk of tagging the steering linkage.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
jbates346
Oct 21, 2015 01:50 PM
Scorched1984
Sep 15, 2015 03:42 PM
FormulasOnly
Sep 10, 2015 09:07 PM
