Rear Control Arms
Old Aug 13, 2005 | 01:54 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Rear Control Arms
If anyone is thinking of reinforcing your rear sup. lower control arms you should check this out. I mean this is no sub. for a set of Spohn lower control arms but the price is right. About $6 apiece at your local Chev Dealer (see pic #21 #10000097).
Auggie
Old Aug 13, 2005 | 02:07 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
do you have a picture of the actual piece?
Old Aug 13, 2005 | 02:30 PM
Auggie's Avatar
No I don't but I bought two of them. They are made out of steel and are: Center to center length = around 5 5/8"
Width = 1 3/16"
Thickness = .105"
If you will look at your lower control arms you will see a series of (6) holes (3 per side) and I assume that they are 5 5/8" apart and can be installed from the bottom with out even removing the lower control arm. I don't know though which two holes (there are (3)) to use yet but that should work itself out. There are four bolts required and there size is as follows: MM 10x1.5x55. With a little work I am sure you could use std nuts and bolts.
Auggie
Old Aug 14, 2005 | 03:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Theses were used on the G-bodies to mount the sway bar without collapsing the a-arm. Some camaro arms already have them, at least the ones that I've messed with have.
Old Aug 15, 2005 | 10:49 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Yep, I've noticed that some camaros from 82-86 (atleast from what I've seen in the junkyards) got them. At the time I figured why not, and snagged a couple for myself. In theory, they box the lca's in that 5 or so inch section for which they bolt into.. gains are quite negligible, however they cost next to nothing. I think a better way to go about this would be to buy some square tubing that would fit inside the lca, cut it to fit snugly between the bushings, drill them to match with the holes in the lca and bolt them in... or just weld plates in like other people have done.
Here are pics of the brackets I used.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
