Adjustable suspension ???
Old Aug 24, 2005 | 01:15 PM
memyselfandkitt's Avatar
Car: 1982 Pontiac Firebird
Engine: 305 5 ltr V8
Transmission: Manual
Can anyone shed any light on if adjustable rear suspension.
My firebird has what looks like a tire valve located in the rear of the boot and would like to know if this is standard????.Also what pressure it would take due to the writing that is on the cap has worn away
Old Aug 25, 2005 | 11:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The factory rear suspensions on these cars were non adjustable. The only way to tinker with position is by implementing a variety of adjustable parts. I am not sure what "valve" you are refering to back there. You can only fill up the tires back there.
Old Aug 25, 2005 | 11:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I would image you are looking at a zirk fitting (for greasing, not air). Can you take a picture of it?
Old Aug 25, 2005 | 11:43 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
prior owner could have installed airbags/ shocks
Old Aug 26, 2005 | 01:06 PM
The valve that is in the boot is located on the inside level with the lock.If you trace the cable that is connected to the valve it goes somewhere near the rear axles / struts.It isnt anything to do with the tires but has a tire valve.Apparently the prvious owner said that it was for adjusting the rear suspension height.
Old Aug 26, 2005 | 01:11 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
http://thunderracing.com/catalog/?ac...&vid=6&pcid=16
im guessing its something like this...let some air out and see how it goes.
Old Aug 26, 2005 | 02:11 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Could be air shocks.
Old Aug 26, 2005 | 09:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sounds like you have/had an air bag(s) installed in the rear springs. Put some air in and see what happens. The air bags shouldn't hold more than about 25 psi.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
J-money
Jan 4, 2019 09:45 AM
Mark_ZZ3
May 24, 2018 01:02 PM
loud91rs
Oct 5, 2015 10:05 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
