will 18's raise my car?
Old Sep 15, 2005 | 03:49 PM
klumb15's Avatar
just a qucik question here, will 18's raise my car up at all? I need like an inch more of ground clearance...just wondering if once i get my 18's on, will they raise the car up just enough...
Old Sep 15, 2005 | 04:11 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
if you go with a higher series of tire.....to keep my car at normal height with 18's I had to have a 45r up front and 35r in the rear.....I guess we'd have to know how wide you want to go too
Old Sep 15, 2005 | 04:47 PM
klumb15's Avatar
they are 8" wide wheels, so I'm guessing like 255's all around...what size shoudl I get if I want to raise the car up? I want some meaty tires with some sidewall, i hate people with big rims, and really little rubberbands on them...
Old Sep 15, 2005 | 06:47 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
get like a 245 45 18 and that will be taller, i have a 245 40 18 in the front and its stock size. i think a 245 50 18 would be way too big .
Old Sep 15, 2005 | 07:41 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Check out my website..plenty of pics. I have 255/45/18's and my car is slammed.
I have more than enough clearance.
Tommy
Old Sep 15, 2005 | 08:15 PM
geez, really you hate all of us? That's not good considering we're trying to help you
Old Sep 15, 2005 | 08:25 PM
klumb15's Avatar
No you guys keep up on your cars, like checking air pressure and stuff...my buddy was too cheap and put 17's on his new grand am, with the skinniest sidewall tires i've ever seen...the wheel well gap was BIGGER than stock, and he always ran them with low air so it looked like the rim was resting on the pavement..those are the cars I hate....i haven't seen a thirdgen with super skinny sidewall tires , wait I take that back, I saw one with 20s that was really skinny, but the majority of them, even the ones with the 20's still have enough meat on them...
mr. iroc, your car is friggen awesome...good work...how much is that dropped? looks great. Are those custom stretched wheels or did you buy them somewhere...so you guys think 245/45 is the way to go?
Old Sep 15, 2005 | 10:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If your car has 245/50-16's then 245/45-18's will raise the car 1/2"
Your going to need a 245/50-18 or 275/45-18 for a 1" raise. Good luck finding tires in those sizes.
Old Sep 15, 2005 | 10:14 PM
klumb15's Avatar
okay sweet...i'll go with the 245/45/18's...just outta curiosity, how much do 20's raise a thirdgen up?
Old Sep 15, 2005 | 10:24 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
245/45's will only raise the car 1/2".
Rim size doesn't matter, it matter how tall of tires you put on the rim.
http://www.miata.net/garage/tirecalc.html
Old Sep 16, 2005 | 12:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
What tire size do you have now,,, that you want to go 1" higher on?
Old Sep 16, 2005 | 12:50 PM
klumb15's Avatar
i have the stock 16's, with 245 and whatever...i just want some lift out of it, anything will be an impovement...
Old Sep 16, 2005 | 02:24 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Looks like you got an IROCZ, like me. The factory tire size is P245/50R16. The tire diameter is: 25.67"... If you want to raise the car up 1" (which I question) you will need a tire diameter around 27.6" to 27.7". Checking thru the 18s, there is no good choice at that diameter. Howver, to raise the car 1/2", the P245/45R18 is at 26.65" diameter. BUT, you will be rubbing and the speedo will indicate a wrong speed.
The proper way to raise your car is with different springs. I recommend that you forget about bigger diameter tires and but new springs that will raise the car 1".
Old Sep 16, 2005 | 03:49 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Old Sep 16, 2005 | 04:09 PM
klumb15's Avatar
well this question was just outta curiousity..so i'd be pleased with even a half inch...its just the exhaust touches once in a while if i dont' pay attention...but nothin major...
My speedo is already messed up...i just put 3.73's in it, and its outta whack pretty bad..
so thankyou for all the info, its greatly appreciated...i'll go with the 245/45's, sounds like the best one to get..
Old Sep 17, 2005 | 03:22 PM
Kandied91z's Avatar
then why are you considering 18's...?
anything in the 26.1-26.9" dia will raise your car up the way your asking. i have a 26.7 dia with my 19's in the rear but personally it's too tall for me. i like to stay 25.5-25.9 to keep it looking right.
Old Sep 18, 2005 | 09:29 AM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Tommy
Nice pics bro, awesome car. I've been wondering how much clearance I am going to have. Running Eibach pro kit springs and getting my SLP Zr1 17x8's with 255/45/17 Falkens inatalled on Tuesday.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
