Stripping weight
Old Oct 24, 2005 | 09:16 AM
WoostahGTA's Avatar
Car: 1990 Trans AM GTA
Stripping weight
I'd like to trim my car down as much as possible, where to start? I already removed the useless backseat, and am going to work on the sound insulation, the spare tires going to be gone soon to. I'd like to install some drag brakes up front, but the car needs to be pretty light for them to be safe. Also skinnier front wheels and tires are in the plan, and I'd like to keep the front sway bar. Anyone know of any other free or cheap weightsaving measures?
Old Oct 24, 2005 | 02:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I can list a few pages of weight savings. Is this a track only car or does it need to be kept street safe?
Easiest way to look at it is if it isn't required to make the car fast or safe, take it out.
My car is strip only and I've removed so much stuff that it could never be made into a street car again.
Old Oct 24, 2005 | 08:02 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
-removed all A/C & heat components (60lbs)
-removed useless rear seatbacks (15lbs)
-installed CORBEAU racing seats (15lbs)
-removed spare tire and jack (40lbs)
-changed spoiler (25lbs)..stock TA foam is 29.5lbs
-removed smog/AIR system & passenger side accy bracket (25lbs)
-relocated battery to back (35lbs front to back)
-added headers (13lbs)
-LT1 aluminum heads (60lbs)
-Mini-starter (10lbs)
-removed catalytic converter (15lbs)
-Fiberglass hood (50lbs)
Straight copy and paste off of my Cardomain site. There's still more that can be cut I'm sure. I'm trying to keep the car as streetable as possible. I will probably be putting the defroster back in though to make it possible to drive on cool days when there is going to be moisture on the windows. I want to weigh my car, it should be really close to 3000lbs (without me) once I put the fiberglass hood on.
The rear seat bottoms are worth like 3lbs total, and the belts are another like 5lbs, so I left them in there. Had them out and then realized how nice it is to have back seats sometimes when you have to drive the girlfriend and her little brother around. Took the seat backs out back there, that's the heavy part, and pillows back there make it more bearable.
I don't have much more planned in terms of weight reductions except for my tubular suspension stuff (rear LCAs, aluminum PHB). Eventually I'll buy some tubular front A-arms and probably swap to coilovers, but that's not in the plans for awhile.
My car will actually gain weight by spring, in terms of finally installing my Spohn SFCs, and possibly a roll-bar/cage.
Old Oct 26, 2005 | 08:33 AM
WoostahGTA's Avatar
The car will be a street car, but noise abatement, A/C, etc. are low on my priority list.
Thanks for the list Duron.
Old Oct 26, 2005 | 11:14 AM
1bad86z's Avatar
Car: 1986 IROC-Z
Engine: 421 SBC
Transmission: T350 w/brake
I have been racing at 3320lbs. with me in my 86Z. I have gone 9.33 @ 148 on 175 shot NOS. NHRA legal.
I still have the crash beams in my doors and I still haven't pulled everything out under the dash. Stock carpet in the rear of car but I will be getting an ACC piece to replace. I will be shootin for 8's next season.
Old Oct 26, 2005 | 01:51 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I wouldn't know about the rest of your list, but I do have direct experience with the fiberglass numbers. I haven't weighted my ram air hood, but I remember it having a shipping weight in the high 30's. The stock IROC hood is around 65, so that only gives you ~ 35 lbs difference assuming the GTA/TA/FB hood is about the same weight as the IROC hood.
The spoiler is defiantly right on. That stocker was a heavy POS. I can't believe that GM put a piece of painted rubber in direct sun light and expected it to hold up.
As for the crash beams, if you're going to be installing a cage it's pretty safe to take them out.
Old Oct 26, 2005 | 03:09 PM
Car: 1997 Corvette
Based on numbers on VFN Fiberglass's website, they say their bolt-on hoods weigh in at 17lbs and their pin-on hoods weigh 12lbs or so.
Don't have my ASCD Ram Air 1 hood yet (its at a buddy's house) so I haven't gotten a chance to weigh it yet.
Old Oct 28, 2005 | 12:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Few days old, but bringing it back up.
Stock 3piece 91 camaro rear spoiler, 6lbs.
GM hood blisters, 9lbs.
Anyone know the weight of the 82-83 camaro fiberglass hood?
Old Oct 28, 2005 | 08:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
No but it's still heavy. I've had a few of them now and I've also left a few in the junkyard. I have one sitting outside my garage with an Aero scoop molded into it. There's enough bondo in it to add about 10 more pounds. I trashed another one trying some modifications to it. The current one I have has a 6" cowl bolted to the hood as seen in the below picture. I used a bunch of nice stainless screws to attach the cowl. It was nicer and cleaner than trying to mold it in.
Although I can unbolt the hood from the hinges and lift it off if I need to, it's not something I would want to do as a complete lift off hood at the track. It would still be a 2 man job to easily take the hood off and on. It's still lighter than a steel hood!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Damon
Sep 26, 2015 04:29 PM
