TQ arm question about front mounting
Old Nov 17, 2005 | 02:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
On the torque arm, I noticed one aftermarket company provided a cross member where you could adjust the height of the front mounting point.
What does changing the front height mounting point do for us?
I'm still half new on understanding how the suspension works, so keep it kinda simple please.
Old Nov 17, 2005 | 03:17 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
changing the height of the mount really doesn't do anything, as the instant center is controled by the for/aft location of the mount, and the angle of the LCA, and the point in which the plane created by the mount point of the TA, intersects the plane of the LCA's.
Do you have a picture of the mount? If i can see it, i can probably give a better explanation of what it is for.
Old Nov 17, 2005 | 03:20 PM
Dale's Avatar
Engine: 350 S-TPI
I'll have to hunt the picture down. I remember seeing it, but I dont remember the brand
Old Nov 17, 2005 | 03:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
The only other thing I can image, is that you talking about something like this...
or this...
Those are decoupled torque arms, that is a whole diffrent ball game, where is uses a sliding link, to allow the instant center to be diffrent under accelleration and decell.
The last and final option, is that the company of the TA you are speaking of, is using the mounting point, as a pinion angle adjustment tool. moving the location of the mount up/down will have an effect on the pinion angle, but from that far away, it takes a pretty big change, to really effect the pinion angle.
--John
Old Nov 17, 2005 | 03:58 PM
Dale's Avatar
Engine: 350 S-TPI
Nope, not them. This was a crossmember, it had the tranny point, and two vertical plates with lots of holes in them to the left of the tranny point.
I belive it was painted blue.
Quick search didnt find it. I'm about to head home, so I will look to see if I saved the picture. Whos to even say it was for a f-body. What other cars use tq arms?
Old Nov 17, 2005 | 04:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
There are many mustangs that convert to a torque arm setup.
Old Nov 17, 2005 | 04:33 PM
Dale's Avatar
Engine: 350 S-TPI
ok, I was quite a bit off. Its just a crossmember, and its red.
But changing the height of the front mount point wouldnt do much?
Old Nov 17, 2005 | 04:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
who's product is that? I'm not even sure how it can function properly, it allows for no for/aft movement of the TA, which is needed since the length changes slightly due the the diffrent arc of the LCA's.
Old Nov 17, 2005 | 08:27 PM
Dale's Avatar
Engine: 350 S-TPI
I'm not sure, saved it atleast a year ago or so.
I belive you are to install a busing in that "C" thing, and the tq arm still slips frontwards/backwards like the stock setup.
Was wondering what advantages were of that height adjustability.
Sounds like nothing worth making some custom bracket work.
Old Nov 17, 2005 | 08:33 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Up/down adjustment would adjust the pinion angle. Same thing is acomplished with most other torque arms where there's an adjusting slider near the rear.
Kevin D.
Old Nov 17, 2005 | 10:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I pointed that out earlier. But you don't get much pinion change when you move the mount 1/2" at the other end of the TA.
Old Nov 18, 2005 | 07:32 AM
Dale's Avatar
Engine: 350 S-TPI
thanks guys. More I look at it, I wonder if its even for a thirdgen. Notice how the cars right side mount point is higher then the left side. Is that the way a 4th gen is?
Odd design.
Old Nov 18, 2005 | 10:50 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Thats for a 4th gen and it is a BMR peice.
http://www.bmrfabrication.com/F-bodyChassis.htm
By using a non adjustable torque arm and by having different mounting holes, You'll be able to change your pinion angle. Like Dewey said, not by much though. It also allows the use of a stock bushing, along with the stock half shell... I think that is how it works. It's been a while since I've seen the installed pics of that.
Old Nov 18, 2005 | 11:28 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks Kat, Now we know whos it is.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
