Lowered car, Alstons & ground clearance?
Old Dec 28, 2005 | 10:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Those of you that installed the Alston SFC's on a lowered car, how much ground clearance did you lose? Are you guys scraping speed bumps worse now?
Thanks!
Old Dec 28, 2005 | 10:46 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Hello Tom,
Speed bumps were the least of my worries until I bought my 85 Iroc lowered 1.5 inches. Now I scrape on an ant screwing the queen, JK. I can hear a sound coming from the rear of the car and I swear that it sounds like tires scraping but AI cannot find any proof or evidence that they are. Strangest thing, I have even checked the clearance in park and it seems ok. What do you think?
Old Dec 29, 2005 | 09:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm lowered an inch and will scrape speed bumps every now and then- that's why I'm concerned about what I'll lose if I put the Alstons on. Do you have the Alston subframe connectors?
Old Dec 29, 2005 | 09:14 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I wish I knew what the car had. I just got her recently and I am still finding out what she has with no help from the owner. I will le you know when I find out.
Old Dec 29, 2005 | 04:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
OK, so, anyone with the Alstons- ground clearance?
Old Dec 29, 2005 | 07:17 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
I lost at least a half an inch of ground clearance. I now scrape speed bumps where I didn't before. Anyhoo, I knew it, I knew it, should have gone with Spohn's. Also, I thought the Alstons where a pain to install and they didn't clear the exhaust very well (a lot of extra cutting, grinding and welding to fix). I'm sure the Spohns would install much easier and not have the exhaust clearance problems like the Alstons.
Old Jan 6, 2006 | 02:32 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
My car is lowered w/ the Eibach pro-kit. I also have the Alston SFC's. I am running stock single-cat exhaust.
In the past two years I think I have only scraped 3 times. (2 speed bumps, and 1 steep driveway) Just remember that your car is LOW and take it SLOW. Also learn to go over things at unusual angles, and youll be fine.
My alstons did not have the best fit. So I sent them back to Alston explaining the problem. They fixed the SFC's, and now they fit like a glove.
They were bolted and welded.
Old Jan 6, 2006 | 03:54 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
My Alston's haven't ever scraped, but then, my car isn't lowered either. My
driveway is fairly steep, and I scrape my air dam every day, so I don't want to
lower it and scrape paint. But they weren't bad going in....
Old Jan 6, 2006 | 04:10 PM
camarobeast84's Avatar
I don't have the alstons, I went with spohn, but my car is lowered 1"3/4 and I never scrape unless theres a very steep drop. Like TAdan said take it slow!
Old Jan 7, 2006 | 07:58 PM
ckeene502's Avatar
i have had them on 3 camaros. i really like them. they fit really crappy on the front passenger mount though.
i think of them as skid rails!!!
Old Jan 7, 2006 | 08:29 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
My car is lowered about 1.5 inches and I have NEVER scraped my Alston's...exhaust is another story
Old Jan 17, 2006 | 01:12 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I have them on my Z with sprotlines and I will hit the cats before the SFC.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
kah992
Aug 19, 2015 02:55 PM
anesthes
Aug 8, 2015 09:37 PM
