Thoght it was the rag joint...
Old Mar 21, 2006 | 07:47 PM
sam's Avatar
sam
Well people,
I am sure someone has a quick answer. So her goes
I have play in my steering and was about to order a rag joint, mounts at the end of the steering shaft right before the power steering...
well I decided to make sure and pulled the plastic cover that covers the shaft, hopefully you know what I am talking about.
Well I could rotat the shaft left and right but the play was NOT in the rag joint but in the actual box, and i believe that box is either the powersteering, steering geer or possible both.
Anyway, does this meen it is shot? Looks like the only fix is to unmount it and from what i can see it will be a pain.
any components that can be swapped out or do I have to chage the whole thing?
I have no idea about prices on parts yet. anyone had it fixed by a shop? if so how much does it run to do?
Thanks,
sam
Old Mar 21, 2006 | 11:44 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
If you narrowed it down to the steering box, have you tried adjusting it? Try reading RB83L69's post in this thread, Rag Joint - Makes big difference?. I would check its adjustment before resigning to the fact that your steering box is shot.
Old Mar 22, 2006 | 03:17 PM
sam's Avatar
sam
Thanks for that link.
Can anyone go into detail on adjustign the steering column play in the box. the play is righ after the rag joint.
Old Mar 26, 2006 | 10:09 PM
sam's Avatar
sam
anyone?
Do i have to unbolt it from the car to adjust it?
Old Mar 26, 2006 | 10:53 PM
Jade Grey's Avatar
Engine: 305TPI
No, you do not have remove the steering box. Re-read RB83L69's fourth paragraph in his first post in the linked thread. He details adjustment.
Old Mar 27, 2006 | 01:32 PM
sam's Avatar
sam
Sounds good. I will look into adjusting it tomorrow if the weather is nice.
The post you are refering to mentions using a spanner but does not really go into detail of the actual adjusting process. Things like should it shaft be unmounted then adjusted or adjusted with the shaft in the box?
Anything that you might be able to think of that is not mentioned in the post you are refering to would be very helpful
Sam
Old Mar 29, 2006 | 06:40 PM
sam's Avatar
sam
Guys, can anyone expain the adjustment?
I looked righ after the ragjoint and there is one bolt about 1.5 inches. That is the bold that tightes the one shaft over the other. Is that what needs adjustment ? The description being referenced to in an earlier post does NOT explain much so I can really use some help
Old Apr 3, 2006 | 04:03 PM
sam's Avatar
sam
I could really use some help...
Old Apr 3, 2006 | 09:28 PM
Hulk0202's Avatar
I sold my Bird over a year ago, so I'm going by memory, but.... If your talking about the adjustment for the steering box, there is a nut on the top of the box that is threaded over an allen head bolt. You have to loosen the nut, and tighten the bolt down. But if I remember correctly, there is a very limited amount of adjustment, and you have to be carefull not to do it too much and crush it. I think your are supposed to turn it until you feel the first bit of tension. Hope this helps.
Old Apr 4, 2006 | 01:10 AM
sam's Avatar
sam
thanks for the reply,
I was refering to the other adjustment. the one that takes play out oof the shaft entering the box.
Sam
Old Apr 4, 2006 | 12:02 PM
camarodarrell's Avatar
Go to this link, The Monte Carlo Mailing List: Tech Articles
Old Apr 4, 2006 | 05:35 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
Originally Posted by h-town z
Great read h-town z, thanks a lot! - Adam
RS Reaper
Sep 27, 2015 07:04 PM
bubbaz28
Sep 18, 2015 02:09 PM
383 Smoka
Feb 8, 2002 03:52 AM
JAY87GTA
Oct 6, 2000 07:01 PM
