t5 torque arm outer bracket discontinued
Old Mar 31, 2006 | 12:26 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Well I just got the bad news from Gm that the outer bracket for the t5
for the torque arm is discontinued but they still sell the inner bracket.
If I cant get this soon Ill have to torch the auto bracket and bend it maybe
or use duct tape..
Old Apr 2, 2006 | 01:13 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Are you talking about a GM#10034259 outer bracket used '84-'90? Is it possible to swap the bracketry for the design used in the later '91-'92 manual transmission cars?
Old Apr 2, 2006 | 03:18 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
T5 torque arm bracket
10024028 and 10024025
These are the numbers I got from doing a search for the inner and outer
bracket. I have contacted Gm parts to see if there correct.
They did reply that the outer bracket is discontinued.
I dont know the answer for your question .
I am switching from auto to manual and for sure the auto bracket is no good for the T5.
So right now I am in limbo land..
Old Apr 2, 2006 | 08:44 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
I may have an extra one in my shed, I'll go take a look tomorrow after work.
Old Apr 2, 2006 | 09:29 PM
Jade Grey's Avatar
Engine: 305TPI
Those are the numbers from the '91-'92 T5 cars. On www.gmpartsdirect.com's lookup, it still shows both. I guess you can't trust it.
Old Apr 2, 2006 | 09:50 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
That would be great news for me thanks for checking.
Old Apr 2, 2006 | 09:56 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I tried to order parts before from that website but wont take any of my creditcards so I ordered parts from this one.
Puritan Pontiac-Gmc/NEW GM PARTS
This is where I got the news that the outer bracket was discontinued.
Still waiting for a confirmation with the part number from puritan.
Old Apr 3, 2006 | 12:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
sounds like a part one of our great vendors need to start duplicating
*hint hint*
Old Apr 3, 2006 | 04:37 PM
ChevyGuy87's Avatar
Engine: 4.0
Well, I just checked and it isn't there. Must've gone to the junkyard with the old Trans Am. Good luck finding one.
Old Apr 15, 2006 | 06:13 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I ordered the outer bracket from Puritan pats the bushing is not correct
for my setup its shaped like flat ... ?? perhaps for the 4th gen torque arm
The bracket could be usable the upper hole lines up with the inner
bracket.
Old Dec 2, 2010 | 06:00 PM
Pyrofrosty's Avatar
Re: t5 torque arm outer bracket discontinued
or use duct tape..
Hi seeing that I am in the middle of doing a 89rs v6 and replacing the old stuff with a smallblock and 350 trans I learned something!! The b&m kit works fine the issue is really bad directions. Your factory trans outer isolator bracket will work, they just don't say that. Yes you have to tweak it a bit and buy the aftermarket inner. What they also leave out is what you have to go thru in the process. The directions are as clear as mud. I will post more with photos in the next few days.
Old Aug 19, 2019 | 01:45 PM
Dillon Brock's Avatar
If u have one ill take it!! Pay pal ready! 84seven seven22 two810 call or text!
armybyrd
Sep 26, 2015 03:37 PM
PyRo9862
Mar 19, 2006 06:39 PM
CamaroGuy868791
Mar 28, 2005 05:47 AM
