How to make it feel like new?
Old Jul 3, 2006 | 01:08 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
After driving my friends and family's newer cars then getting back in my TA, the ride and handling is entirely different. The steering is loose, doesn't feel as tight, etc. So assuming everything in the car is stock, what will make the biggest difference in replacing/upgrading?
Old Jul 3, 2006 | 01:49 PM
j dezzy's Avatar
Car: 87 TA
I put new shocks, struts, linkage and steering gear in my bird and it drove like new. felt real smooth.
Old Jul 3, 2006 | 11:45 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
subrame connectors takes my vote,
but most of bushings in suspension are most likely somewhat worn out.
TA wasnt probably made for the most comfortable/quite ride,
so u can probably add some sound deadner under the carpet(it already has factory deadner, but u can add more beneath)
and u can feel the quite/smooth ride like newer cars.
shocks/struts and motor/tranny mounts are must also
if they're old.
Old Jul 4, 2006 | 12:34 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I constantly wonder the same question. BUT, when I do the push down on the car and count the bounces test, the car comes back within the first bounce. Will we be wasting our money going with new struts, or will a diffrence be felt?
Old Jul 4, 2006 | 01:00 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
just cause they rebound properly under you pushing on them wouldnt mean there not giving you a bad ride when they you are going very fast. you have to keep in mind that they have to control 750+ pounds of steel bouncing around in probably thousands of cycles.
I felt a HUGE difference in how my car rode after i replaced all the Bushings on the front end. i still need to fix the Steering and rears but just that made the car react totaly different.
Old Jul 4, 2006 | 11:28 AM
Car: 86 T/A
Engine: HSR 355
Yeah I think the upfront linkage is always overlooked and is critical to the feel of the car. When I get it on the road I'm definitely going to look into replacing it all.
Old Jul 4, 2006 | 07:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you don't have it - first thing would be the wonderbar - it makes a tremendous difference, and having it installed will allow you to "feel" other problems. I had a bad idler arm, but didn't know it until I installed the TDS wonderbar - it's the best 50 suspension dollars you can spend!
Old Jul 4, 2006 | 09:52 PM
j dezzy's Avatar
Car: 87 TA
Where can you buy the wonder bar at?
Old Jul 5, 2006 | 07:51 PM
Car: 1992 RS
Engine: Carbed 350
You can grab one off any Iroc - Junkyard part maybe $30.
TDS (Top Down Solutions) makes a very nice one for $50 - he's a sponsor on here and a great guy to order from...
Top-DownSolutions.com
Old Jul 5, 2006 | 08:23 PM
j dezzy's Avatar
Car: 87 TA
I've actually checked my junk yards and had no luck. is the one from TDS just as good?
Old Jul 5, 2006 | 08:41 PM
Car: 1992 RS
Engine: Carbed 350
I'd say it's better! A great product, and TDS a great company to deal with - you won't be dissapointed.
Old Jul 5, 2006 | 08:47 PM
j dezzy's Avatar
Car: 87 TA
Thanks. I'll order one here soon.
Old Jul 10, 2006 | 01:47 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Yeah, I felt a HUGE difference from my front end rebuild (tie rod ends, ball joints, etc) and all new bushings all around, with struts and shocks. I also put the TDS wonderbar on.......
All I can say is that this is a MUST for these old cars if it has never been done before.
Old Jul 10, 2006 | 10:45 PM
eddie jr's Avatar
Just wondering, what did the bad ideler arm "feel" like?
Old Jul 11, 2006 | 07:34 PM
Car: 1992 RS
Engine: Carbed 350
Bad idler arm really didn't "feel" much at all - after I installed the wonderbar I got a new noise, a clunking noise as I remember, when I turned sharply (like in a parking lot space), and I found the loosened, old, worn idler arm.
Old Jul 11, 2006 | 09:09 PM
The Phantom's Avatar
I have purchased all the items listed here on line E-bay etc ... I have listened to these guys and taken there sound advice. I am now putting it all together, if this car doesn't handle like a slot car I will be very suprised!
I have also replaced the camber plates with the Hot Part units ... hey in for a penny!!!
Dave
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
86White_T/A305
Aug 17, 2015 12:16 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
