Driving around with no struts
Old Jul 26, 2006 | 06:15 PM
Rosadoc-Z's Avatar
Car: 1987 Camaro IROC-Z
Engine: 350 5.7 TPI
I bought my '87 IROC earlier this summer and I thought I checked everything but something as obvious as the struts slipped by me. I took the car to get some other work done and as they lifted it up, we noticed that it had no front struts, just the spring. I never even noticed this while driving. The suspension feels normal so i never really caught the fact that it was missing struts. I dont know how long its been like this but what damage can i do if I keep going like this?
Oh and what good struts do you guys recommend?
Old Jul 26, 2006 | 06:22 PM
j dezzy's Avatar
Car: 87 TA
Not sure what kind of damage it can do...if any...but I recomend picking up some struts soon.
Old Jul 26, 2006 | 06:34 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Nothing was bolted to the steering knuckle??? so the wheel was only held on by the ball joint and tie-rod??? Or am I missing something in the way it works....
Old Jul 26, 2006 | 07:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Impossible.
Old Jul 26, 2006 | 07:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it had no struts, it wouldn't be driving anywhere.
Old Jul 26, 2006 | 08:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Maybe in the back
Old Jul 26, 2006 | 10:02 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah thats impossible
someone is smokin too much
the rears are just shocks
you can drive without them but the rear end will non stop bounce and float like a boat on big waves
good luck
Old Jul 26, 2006 | 10:42 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I recommend taking the car somewhere else.
What they told you is like a plane flying without a propeller.
Old Jul 26, 2006 | 11:13 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
If the car had no struts ( If they were out of the car )
The tires would fold into the car and it would be impossible to move
I am quite sure that if you drove it there they are only worn out badly and that is what the mechanic meant by saying you have no struts.
Old Jul 27, 2006 | 06:23 AM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
Yeah you guys are right, i went there and took a good look and my mechanic must be on something because there was definetly struts on the car. Over the phone he was saying "you know the car has no front shocks right?" He wasnt there for me to question him though. What confuses me is that the shop works almost exclusively with f-body's, corvettes, and other american cars, so i expected them to know something. Sorry about this. Close thread.
Old Jul 27, 2006 | 12:33 PM
Shagwell's Avatar
Car: projects.......
As he said, the car has no front shocks...which in never did. - He probably looked at the a-arm and noticed the shock bolt holes in the coil-spring pocket. If the a-arms had been on...(g-body? I think) they would have a shock bolted up through the coil spring area.
Deffinitely has struts on it, they may be worn out, but if it's driving they're deffinitely on there.
Frozer!!!
Jan 19, 2024 04:55 PM
NORTz89
May 20, 2020 03:51 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
