Best tire size for 17x8 with 0mm offset
Old Sep 13, 2006 | 12:02 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I am thinking of getting the American Racing Ansen wheels. They come in a 17x8 size with 4.5" backspacing. Should I run 275/40/17 on the front and rear. From what I've been reading on the search I've seen people go larger, but unsure of what backspacing they had. Thanks.
Old Sep 13, 2006 | 01:53 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Old Sep 14, 2006 | 01:24 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
255/40-17
Old Sep 14, 2006 | 09:51 AM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
i run 17x8's too. go 245/45/17. 275's would only work in the back, and you want to be able to rotate your tires. 240's look to skinny on the wheel. 255's well....thats just a wierd size.
Old Sep 16, 2006 | 10:22 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I have 275's on my front 17x8.5's. I think the sidewall bulges to much. So 275 on a 17x8 should not be considered. 245's will be fine, as long as you buy a quality tire. An exspensive 245 will provide more traction than cheap 275's
Old Sep 16, 2006 | 10:58 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I have 255/40 on my 17x8s and i dont like them, they look look too small and they are too small at only 25". Ideal and next time i will go with 245/45.
Old Sep 17, 2006 | 05:56 AM
B Rhodes's Avatar
Car: 91 B4C
according to the tire guide 275/40/17 should be on a min 9 in rim. I run 255/45/17 but 265/40/17 are acceptable for an 8 inch rim also. A wider tire on a small rim isnt going to be any better handling.
Old Sep 17, 2006 | 02:08 PM
Car: 1992 Z03 RS
one more time.........
Old Oct 7, 2006 | 02:36 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Sorry to ask a question that may be obvious, but where is this tire guide talked about above....Discount has tried to hook me up with 275's on 8 inch rims, I would like to know more about what works with what.....
Old Nov 2, 2006 | 05:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Gallileo60,
if you go to BFGoodrich Tires, go to sports car, click on a tire and click details. You will find tire sizes listed with specs, what rim will fit, tire height and section width. Lots of info. By the way a 275 will not fit on a 8".
Old Nov 2, 2006 | 07:19 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Billsblue89, Thanks for the tip......
Old Nov 2, 2006 | 07:27 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Just for a heads up. I have 17x8 wheels with 275's on the rear and the rub the wheel well lip on occastions tearing up the tire. The also make the car swaw a bit in the turns due to the tire sticks out so far past the rim lip.
Old Nov 4, 2006 | 04:19 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks for the heads up...I went with 255 45's back and 245 45's front on 17 inch by 8 rims...seems to work well, but I still would like a bit more meat on the back...Anyone running 265's on 8 inch rims? If so, how is it??? Thanks, Tom
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
knight72
Aug 10, 2015 09:32 PM
