spring question
Old Nov 17, 2006 | 06:22 PM
bfox88's Avatar
Car: 90 IROC-Z
spring question
i just bought a pair of lightly used rear Eibach Pro Kit springs. since i dont have the front springs what are my options for the front that will give me a similiar lowering height and spring rate? could i get the Moog IROC springs and cut them? if this would work how much should be cut off?
Old Nov 17, 2006 | 06:40 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
dont not cut your springs, its unsafe,
i know i cut my springs once on my camaro, the ride was shitty, and the springs came out and ****ed up my car, its not safe, u can kill your self, or someone else
Last edited by jkwild0630; Nov 17, 2006 at 06:42 PM. Reason: Automerged Doublepost
Old Nov 18, 2006 | 01:48 PM
bfox88's Avatar
Car: 90 IROC-Z
hmm i've never heard that before. thanks for the reply? anybody have any feedback on this? i need to know what to do about the fronts.
Old Nov 18, 2006 | 04:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
um, eibach front springs?
you can grab moog 5662's and chop off a bit. Maybe 1" or 1.5" would work alright. You can try 1" and install and drive it for a week and see how you like it, and redo it if you want.
I have no idea how a front spring can fly out on it's own, that boggles my mind. Unless you cut it so much that you're basically on the bump stops, then drove around like the dukes of hazzard. That might do it.
Old Nov 19, 2006 | 08:46 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Please explain how trimming springs is unsafe?......every race car on the planet might explode if I don't let them in on the your little secret.
I second the moog suggestion, just don't cut too much at once. A 1/4 of a coil will drop it a .5" or more.
Old Nov 19, 2006 | 12:34 PM
bfox88's Avatar
Car: 90 IROC-Z
thanks alot guys. i think i'll go with the moog and cutting idea. what did you guys use to cut your's with? would a dremel work? oh and i'm having trouble finding someplace where i can buy just front springs, any suggestions?
Old Nov 19, 2006 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
every parts store in america will have front springs.
Ask for moog/TRW 5662's. Or just "front springs for a '90 Iroc".
That might cross to a moog 5664, that's the stiffer one. But if you're cutting it shorter, that in essence increases the spring rate, so maybe the 5662's will work for ya. (do I have that right?)
Don't use an oxy-acetylene torch to cut it with. Of course that's not a common tool to use anyway, unless you're a farmer.
Use an angle grinder with a cutoff disc. That's about the most common/easiest way to do it. A dremel might work, but you'll go through about 20 discs, and an hour or two, to cut one coil.
A cheap $20 angle grinder, and a $2 zip disc will make short work of it.
1/4 coil =~ 1/2" is good piece of info, thanks BMmonte
Old Nov 19, 2006 | 10:18 PM
bfox88's Avatar
Car: 90 IROC-Z
thanks alot for the replies. i'll have to look into getting an angle grinder, and i'll head up to advanced this weekend and grab the springs
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
