Camaro, SS Hood, TBI Strut Brace....
Old Nov 21, 2006 | 03:40 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
I have the ASCD SS hood on my camaro and just installed Edelbrocks TBI strut brace and now I have a dilema. The hood hits the right and left wheel well mounting brackets. Just wondering if anyone else ran into this mess, if you can give me the 411 on what to do or what I can do, it would be appreciated. I know I should have checked for clearance prior to intalling, but the eagerness to put it on, out weighed the thought process, but wont happen again.
Old Nov 21, 2006 | 03:51 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Try flipping the brace over. Make sure the mounts are on the proper side of the car.
Old Nov 22, 2006 | 09:59 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have the TPI one, and had to file the top of the braces down. File the bolt heads down on top. And even notch the under side hood pan. I used a rubber gasket for trim so it looks clean.
I didnt want to give up either the hood or the brace. so a little work and they fit great.
Old Nov 22, 2006 | 05:56 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I had that problem too....but didn't want to cut into my hood...so...I told the STB "bye bye"
Old Nov 26, 2006 | 11:04 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thats to bad the brace really is a must have. with the subframe connectors it really lets the suspension do its job. The front will wonder with out it. Even with new parts. The towers flex even at low speeds. I rebuilt everything on mine its still felt floaty. Added the brace and it was a whole new car.
The area you have to notch doesnt effect the strength of the hood any ways. And the way its designed in two pieces it pulls air from the scoop and flows thru to the area where its notched. So it helps keep the underhood temps down even more.
And it looks kinda cool to me when the hood is up. Having the openings there.
Old Nov 27, 2006 | 04:31 AM
ABJ88's Avatar
Engine: 5.0/5.7
Please Post Pics.
Old Dec 2, 2006 | 07:03 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Sorry i missed your post...i can take pics of the underside of the hood if you like.
Hows the brace install working out?
Old Dec 20, 2006 | 08:29 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Hey MikeH, I would also like to see what you did to the underside of your SS hood. Im thinking I may do the same as well. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
pimp2303
Jul 27, 2017 02:03 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
