Swaying while driving... need wonder bar?
Old Nov 22, 2006 | 12:35 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
My car is sorta weird. While driving normally, it sways to the right and left alot while just trying to keep it straight. However, when you go fast it is glues to the road. I am wondering if I purchase a wonderbar (UMI of course) if it would help reduce this swerving? I have a very thick front and rear sway bar. SFC's, tubular Lower control arms, prothane links... etc...
Just figure I would throw this out there to see if someone has the same problem?
Old Nov 22, 2006 | 01:31 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
As you know, the wonderbar braces the forward frame rails together to reduce stress applied by the steering box that can cause cracking. If your frame rail where the box mounts is not cracked, you shouldn't notice a difference with the wonderbar. I have a Global West bar on the camaro, priced well for a strong, tubular piece.
Is your issue an over-center tracking issue-constant slight corrections while going straight (steering box/linkage)? When you say it's ok going fast do you mean in a turn/curve (steering box off-center)?
Old Nov 22, 2006 | 11:37 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Okay get this, you are driving straight, going at a speed of around 45 mph. You try and keep the car dead center, but the car as a tendacy to lean toward the left or right.
So you get up on it, 65 mph, car is straight as an arrow stays exactly where you put it.
Now while cornering, the car is very stable and stiff.
First things I think of, front end alignment? No premature tire wear.
Struts not working hard enough?
Springs old and saggy?
Whatever it is, it is not right, I know it is not much info but it is the best way I could discribe it.
Old Nov 23, 2006 | 01:37 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
I would imagine your not used to driving an old style steering box.All cars with this type of steering does it to some extent.I wish GM had put rack and pinion on them.Even my 85 mini van has rack and pinion.GM should have put them on these.It's my only gripe about these cars.
Old Nov 23, 2006 | 02:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think your front end alignment could be off *a tad*.
Or, probably more likely, steering box needs adjustment or replacement. No need for aftermarket parts just to get factory performance, I wouldn't settle for a car you have to "herd" down the road. I'm probably going to replace my steering box to fix this issue on mine.
Old Nov 23, 2006 | 07:02 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
How much are the steering boxes anyways?
Old Nov 24, 2006 | 03:18 AM
1988-305-tbi's Avatar
my car does that to, but it only because i have the steering box adjusted to tight and it doesnt like returning to center, i'm alway correcting it. just my .02
Old Nov 24, 2006 | 08:56 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
most roads suck. try finding a concrete road for your testing..
asphalte(sp) sucks and ruts real bad which gives us groove wander..
Old Nov 24, 2006 | 10:03 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Well I am used to driving a 2001 dodge ram.... I recently gave that to my wife as her daily driver and now my formula is my daily grind. So maybe I am just too used to a newer car?
However, on the flip side, my 88 firebird sorta felt the same as my formula, so maybe it is because of the old steering box...
I knew I should have got a fox body... at least they do have rack and pinion...
but... on a lighter note at least we have 5 lugs lol
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
