lowering springs problem
Old Dec 12, 2006 | 02:06 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
i just had the ebay special tenzo lowering spring put on my car.theback sits about the same but the front is way higher than it was before.i heard that they will settle but it doesn`t look like it will as much as i want it to.anyone have this problem and how did you fix it?
Old Dec 12, 2006 | 04:22 PM
kaptinkafeen's Avatar
Are the (or were the) front springs indexed correctly?
-Andrew
Old Dec 12, 2006 | 05:21 PM
jaysfs's Avatar
Transmission: t56
what do you mean indexed?
Old Dec 12, 2006 | 07:39 PM
The bottom coil of the front spring (where the coil ends) should be positioned in the A-arm between two indexing holes/drain holes. If the coil doesn't sit (or isn't indexed), the front end of the car will sit high and will look like a 4x4. No amount of time will "settle" this problem... Take a look under the car. Raise the front tires up enough so that you can get a good look at the lower a-arm. You will see two small holes on the inside of the arm (closer to the body side). If you look at the pic,
the two small holes nearest the bushing side within the spring pocket - these are the holes on which the bottom coil should rest (or be indexed).
-Andrew
Attached Thumbnails lowering springs problem-arn-painted-new-poly
Old Dec 13, 2006 | 10:20 AM
jaysfs's Avatar
Transmission: t56
thanks for the info man,i will have too check that out when i get it back this weekend,hopefully thats it. i will let you know
Old Dec 31, 2006 | 02:07 PM
jaysfs's Avatar
Transmission: t56
i got my car back kast night and the springs are where they should be.
Old Dec 31, 2006 | 02:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Are you saying the front sits higher than the back now, or just that the front sits higher than it did before the swap...
If the front is sitting higher than before, but not higher than the back theirs probably nothing wrong. Keep in mind the car is 15 years old and those original springs were bagged out and sagging...
If the front sits higher than the back i would say they sent the wrong front springs...
Old Jan 1, 2007 | 08:43 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Sounds like the shop didn't get the spring in the upper seat correctly. This will raise the car substantially.
Old Jan 2, 2007 | 07:54 PM
jaysfs's Avatar
Transmission: t56
the spring is where it should be and the rears sits low.the front end sits higher than it did before i replaced them by three or four inches.i` just going too cut a coil or two to lower it this weekend
Old Jan 7, 2007 | 01:35 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i had the same prob when i installed my lowering springs, looked at it a couple of times, the top of the spring did not seat just the right way at the top. get a flashlight and take a look.
Old Jan 9, 2007 | 10:07 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Nooo! Don't cut the spring. If you can't fix it take it to someone who can. The spring is not seated in the upper cup properly. Do you really think a lowering spring will raise your car 3" without you cutting it? No.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
