which roll cage?
Car: 91 Z
Engine: Somethin Nice!!
which roll cage?
is there a complete roll cage kit that the front roof bars go downwards along the angle of the a pillar? ive seen som pics of ones like this and to make them work you must cut away at some of the dashboard for the front bars to go through down to the floor. and then theres the ones that the front bars are angled more towards the floor and dont run parallel with the a pillar but bend to mount in the same location on the floor.(not the one im interested in)
The only way you get the "smoothed in" look is to build it/have it built. Usually the cages that tuck in nicely to the pillars and such were built from scratch. - The kits are usually to generic. .
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Car: 91 Z
are you sure? every pic ive seen of these installed shows the front bars bending to avoid cutting of the dash and they angle downward more to do so which i think looks ugly since the bars dont run parallel with a pillars?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
